NAT with c4500
rafern0027
I have this supervisor WS-X45-SUP7-E and I use the following image cat4500e-universal.SPA.03.04.02.SG.151-2.SG2.bin
I need to do NAT but when I try to implement
ip nat outside source static XXXX XXXXX
it is not supported
Is NAT support in c450X?
+info
c4507#sh module
Chassis Type : WS-C4507R+E
Power consumed by backplane : 40 Watts
Mod Ports Card Type Model
1 48 10/100/1000BaseT EEE (RJ45) WS-X4748-RJ45-E
2 12 1000BaseX (SFP) WS-X4612-SFP-E
3 4 Sup 7-E 10GE (SFP+), 1000BaseX (SFP) WS-X45-SUP7-E
Julio E. Moisa
NAT is not supported on Cisco Catalyst switches unless you have a Cisco Catalyst 6500 series or Catalyst 5500 with specific IOS. You need a router or firewall to create a NAT.
Please check this link:
http://www.cisco.com/c/en/us/support/docs/ip/network-address-translation-nat/29283-166.html
Please rate the comment if it is useful
>> Marcar como útil o contestado, si la respuesta resolvió la duda, esto ayuda a futuras consultas de otros miembros de la comunidad. <<
