native and hybrid modes
aksher
Level 7
Level 7
whcih command is used to see the native, hybrid modes on layer 3 switch
devang_etcom
Level 11
Level 11
hi aksher,
here you can see the hybrid or native mode...
Console> (enable)dir slot0:
i think there is no any command that show that in proper mode but you have to identify from image name...
here you will get the image name of the IOS and from that you have to identify that switch is runing in hybrid or native mode...
for more detail this link of conversion hybrid to natvie mode will help you to find out the same thing...
http://www.cisco.com/en/US/products/hw/switches/ps708/products_tech_note09186a008070f124.shtml
hope this will help you
rate this post if it helps
regards
Devang
