Native VLAN Question
integrativenutrition
Community Member
If I have a trunk between two switches using 802.1q I understand that the native vlan on both trunk ports needs to match.
My question is, can I just create a new arbitrary vlan and make it the native vlan for the trunk ports on either end?
fb_webuser
Level 11
Level 11
yes, you can very well do that...the purpose of making a VLAN as native is to have the packets from that VLAN go untagged though the trunk....you can create a new VLAN say 10. Go under the trunk interface and type "Switch(config-if)#switchport trunk native vlan 10"....the same command is to be replicated on the other switch
Posted by WebUser Uwais Siddiqi
Reza Sharifi
Yes, you can, as long as that vlan is the same on both sides of the trunk.  Actually,  It is recommended not to use the default native vlan (1) and change it to a different number.
fb_webuser
Level 11
Level 11
Yes, the native VLAN is the VLAN which does not carry a 4-Byte "Q-TAG" specified in the 802.1Q standard , so it is simply used for control plane traffic like CDP. Cisco's recommendation is to avoid using VLAN 1 though. Good luck
So - use any VLAN, just not VLAN 1, and yes - they need to match
Atle
Posted by WebUser Atle Ørn Hardarson
Thanks guys
fb_webuser
Level 11
Level 11
