NDB Embedded installation
Hi Guys,
I am trying to upgrade to NDB embedded 3.6 on a Nexus 3538. When I try to run the activation script (python script) then it fails with 'no space on bootflash'. I have 850m free, how much space is actually needed? I have deleted as much as I can, and cannot delete anything more.
Thanks!
Jacques
Hi Jacques,
I am sorry you are still facing these issues 😞 All points toward insufficient privileges of the account you are using to access the switch.
Please let me ask you: I know you are using the "admin" account - but is this account truly a local account? Additionally, what role is this account assigned to? We need it to be network-admin; network-operator is not enough. Verify this using show user-account.
Thank you!
Best regards,
Peter
12 Replies 12
Peter Paluch
Hello Jacques,
The activator script only creates a tiny text file - there should be no large consumption of a filesystem space required at all.
May I ask you to post the complete transcript of your terminal/SSH session as you try to execute the activator script? Also, from the bash shell on your switch, can you post the output of
mount
df
df -i
Thank you!
Best regards,
Peter
Hi Peter,
I am running the python script from within bash itself. I have seen it in NX-OS as well, should I rather run it from there?
Then in the bash shell it complains about space on bootflash and that I should clean it. Pretty much this gets triggered in the script:
    try:
        with open('/bootflash/interfaces', 'w') as fd:
            fd.write(data)
    except IOError as e:
        logger.error("No space left on the device")
        logger.error("Pls clean up the /bootflash and retry")
        sys.exit()
1 have about 850Mb free when executing it. But in the meantime I managed to upgrade to 3.0 because it does not require the script to run. I will attempt to do 3.6 again tomorrow with all the output you requested. but from within bash:
bash-3.2$ mount df df -i
mount: mount point df does not exist
bash-3.2$
I am running version 6.0(2)A8(6) with 2G bootflash and 4G RAM.
Jacques
Hi Jacques,
Two things:
First, it seems like the commands you have entered got garbled into one line. They are three independent commands, and need to be executed one after another:
mount
df
df -iSecond, are you accessing the switch using the admin username? If not, try logging in as admin and running the script. The error might very well be caused by the script not having enough privileges to create the /bootflash/interfaces file; the IOError exception is not specific.
Best regards,
Peter
Hi Peter,
Sorry about that, see below. I sign into the switch as admin/admin. when I do run bash, it only asks for a password when doing sudo su. Password is blank though, not sure why.
bash-3.2$ mount
/dev/root on / type auto (rw,errors=remount-ro)
proc on /proc type proc (rw)
none on /post type tmpfs (rw,size=2m,mode=777)
none on /var type tmpfs (rw,size=2m,mode=777)
none on /sys type sysfs (rw)
nodev on /debugfs type debugfs (rw)
none on /isan type tmpfs (rw,size=1500m,mode=755)
none on /nxos/tmp type tmpfs (rw,size=40m,mode=777)
none on /var/tmp type tmpfs (rw,size=400m,mode=777)
none on /var/sysmgr type tmpfs (rw,size=900m,mode=777)
none on /var/sysmgr/ftp type tmpfs (rw,size=300m,mode=777)
none on /var/sysmgr/ftp/cores type tmpfs (rw,size=100m,mode=777)
none on /dev/shm type tmpfs (rw,size=628m,mode=755)
none on /volatile type tmpfs (rw,size=100m,mode=777)
none on /debug type tmpfs (rw,size=20m,mode=777)
none on /dev/mqueue type mqueue (rw)
/dev/sda5 on /mnt/cfg/0 type ext3 (rw,nodev,noatime,nodiratime,noacl,data=writeback,commit=15,nouser_xattr,barrier=0,nocheck)
/dev/sda6 on /mnt/cfg/1 type ext3 (rw,nodev,noatime,nodiratime,noacl,data=writeback,commit=15,nouser_xattr,barrier=0,nocheck)
none on /var/sysmgr/startup-cfg type tmpfs (rw,size=400m,mode=777)
devpts on /dev/pts type devpts (rw,noexec,nosuid,newinstance,gid=4,mode=0600,ptmxmode=0666)
/dev/sda4 on /mnt/pss type ext3 (rw,nodev,noatime,nodiratime,noacl,data=writeback,commit=15,nouser_xattr,barrier=0,nocheck)
/dev/mtdblock2 on /mnt/plog type jffs2 (rw,noexec,nodev,noatime)
/dev/sda3 on /bootflash type ext3 (rw,noexec,nodev,noatime,nodiratime,noacl,data=writeback,commit=15,nouser_xattr,barrier=0,nocheck)
/dev/sdb1 on /usbslot1 type vfat (rw,noexec,nosuid,nodev,noatime,quiet,uid=2002,gid=503,umask=0,iocharset=default)
smackfs on /smack type smackfs (rw)
usbfs on /proc/bus/usb type usbfs (rw)
vdccontrol on /cgroup type cgroup (rw,cpu,memory,devices,cpuacct,cpuset)
bash-3.2$ df
Filesystem           1K-blocks      Used Available Use% Mounted on
/dev/root               409600     77232    332368  19% /
none                      2048         4      2044   1% /post
none                    409600     77232    332368  19% /var
none                   1536000    872692    663308  57% /isan
none                     40960       128     40832   1% /nxos/tmp
none                    409600       856    408744   1% /var/tmp
none                    921600        96    921504   1% /var/sysmgr
none                    307200       108    307092   1% /var/sysmgr/ftp
none                    102400         0    102400   0% /var/sysmgr/ftp/cores
none                    643072    170332    472740  27% /dev/shm
none                    102400         0    102400   0% /volatile
none                     20480         0     20480   0% /debug
/dev/sda5                38260      4351     31934  12% /mnt/cfg/0
/dev/sda6                37755      4351     31455  13% /mnt/cfg/1
none                    409600      3952    405648   1% /var/sysmgr/startup-cfg
/dev/sda4                38268      6591     29701  19% /mnt/pss
/dev/mtdblock2           49024      1616     47408   4% /mnt/plog
/dev/sda3              1850752   1043064    713672  60% /bootflash
/dev/sdb1              3922944   1179832   2743112  31% /usbslot1
bash-3.2$ df -i
Filesystem            Inodes   IUsed   IFree IUse% Mounted on
/dev/root             475731    2736  472995    1% /
none                  475731       2  475729    1% /post
none                  475731    2736  472995    1% /var
none                  475731   13204  462527    3% /isan
none                  475731       8  475723    1% /nxos/tmp
none                  475731      82  475649    1% /var/tmp
none                  475731      27  475704    1% /var/sysmgr
none                  475731      13  475718    1% /var/sysmgr/ftp
none                  475731       1  475730    1% /var/sysmgr/ftp/cores
none                  475731     290  475441    1% /dev/shm
none                  475731       1  475730    1% /volatile
none                  475731       1  475730    1% /debug
/dev/sda5               9880      43    9837    1% /mnt/cfg/0
/dev/sda6               9760      43    9717    1% /mnt/cfg/1
none                  475731     582  475149    1% /var/sysmgr/startup-cfg
/dev/sda4               9880     139    9741    2% /mnt/pss
/dev/mtdblock2             0       0       0    -  /mnt/plog
/dev/sda3             235200      78  235122    1% /bootflash
/dev/sdb1                  0       0       0    -  /usbslot1
Hi Jacques,
This is really strange. Let's dig deeper if you don't mind. Can you please execute these commands in succession and post the complete output?
run bash
sudo su
whoami
groups
ls -ald /bootflash
ls -al /bootflash
<run the NDB activator script here>
exit
exit
Thank you!
Best regards,
Peter
Hi Peter, please see attached file.
Jacques
Hi Jacques,
I guess I see the problem:
-rw-r--r--  1  2004 network-operator       126 Jun  4 10:57 interfaces
There already is a file named "interfaces" in your /bootflash but it is owned by an UID (User ID) that no longer exists as a valid user (it certainly isn't "admin"). Since only this user has the write privileges for this file while the group and others only have read privileges, an attempt to open this file by "admin" for write operations necessarily fails. In this sense, the activator script misleads us: For every I/O exception, it just summarily says that the filesystem is full - which may not be the case at all.
Here's my suggestion: Under bash, rename this file (I don't want to delete it, just in case):
run bash
sudo su
mv /bootflash/interfaces /bootflash/interfaces.old
Then try running the activator script again.
Best regards,
Peter
Hi Peter, unfortunately different error now. Looks like I do not have permissions to create a folder:
DC-MON-SW1# run bash
bash-3.2$ sudo su
Password:
bash-3.2$ cd /bootflash/
bash-3.2$ python ndbactivator3.py -v embndb
mkdir: cannot create directory `embndb': Permission denied
Traceback (most recent call last):
  File "ndbactivator3.py", line 275, in <module>
    main()
  File "ndbactivator3.py", line 267, in main
    get_iface_info(options.vservice_name,forceFlag)
  File "ndbactivator3.py", line 111, in get_iface_info
    os.chdir(cont_path+ '/' + dir_name)
OSError: [Errno 2] No such file or directory: '/isan/vdc_1/virtual-instance/embndb/rootfs/embndb'
bash-3.2$ cd /isan/vdc_1/virtual-instance/
bash-3.2$ dir
embndb  ofa_ndbemb
bash-3.2$ cd embndb
bash-3.2$ dir
cisco  rootfs
bash-3.2$ cd rootfs
bash-3.2$ dir
bin   cisco  etc   lib      lost+found  mnt   sbin  tmp  var
boot  dev    home  linuxrc  media       proc  sys   usr  xnclite
bash-3.2$ exit
jacques
Hi Jacques,
It appears that we're constantly fighting problems with permissions. It looks to me that your "admin" account, or whatever account it is that you use to log into the device, is a RADIUS/TACACS+ account, which may result in different UIDs between different logins.
Ideally, we should be using the "admin" account that is created locally and that uses a constant UID.
Here is my suggestion:
  1. Uninstall both the NDB and OF virtual services
  2. Remove the /bootflash/interfaces file if there is any
  3. Install the OF and NDB virtual services again
  4. Run the activator script again
During this process, do not log off - make sure that all these steps are executed in a single terminal session. This will make sure that all the files will be created using your current UID which won't change during the installation. Hopefully, this will make it work.
Best regards,
Peter
Hi Peter, unfortunately same result. I uninstalled ndb and openflow. Removed interfaces file. Reinstalled ndb and openflow. Activated both and then:
bash-3.2$
bash-3.2$ sudo su
Password:
bash-3.2$ python ndbactivator3.py -v ndb
    main()
OSError: [Errno 2] No such file or directory: '/isan/vdc_1/virtual-instance/ndb/rootfs/embndb'
Hi Jacques,
Thank you!
Best regards,
Peter
Hi Peter, I am glad to say I got it sorted out!
For some reason, when I started bash, and do sudo su and it asked for a password, a blank password did not report a authentication failure. Instead it appears that is was accepted. However I realized whoami still reported the user as admin. And the permissions on the folders all had root listed. So I could not even manually create folders there (anywhere for that matter). So I saw somewhere 'sudo su root' in general Linux forums and when I entered that together with the admin password, whoami reported root as the user. So then the script run without any issues.
But thanks for your help it really pointed me in the right direction!
Jacques
