NEAT on c6500
ajf303
Can c6500 sup2t be configured  as a NEAT supplicent???
Mark Malone
Yes it can be used as the supplicent with the correct image
http://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst6500/ios/12-2SX/configuration/guide/book/dot1x.html#wp1147404
Thanks Mark for the reply!!!
I am using latest released image(15.2sy) to configure this..
Below  two commends are not supported on my supplicant switch(C6509-E) port...
dot1x pae supplicant
dot1x credentials neat
Can you pls help...
Yes so mine dont fully support it either its only specifc versions , the way to find out which 1 is to use the feature navigator but if you are running the latest you will prob need to downgrade it to an earlier release
http://tools.cisco.com/ITDIT/CFN/jsp/index.jsp
go to research features
select technology-security vpn-authentication protocols- IEEE802.1x Supplicant
from there you will be able to see what versions supported the syntax
