need a visio stencil for 7206vxr PA-POS-2OC3
dgalati000
I cannot find ANYWHERE a visio stencil for this card.  I can all the other POS PA's on the TAC website, but nOT for this PA..does anyone have a link to this PA ??
mbailey
I don't see this particular PA either, but I see OC3MM/SMI/SML.  I referenced these 2 sites.  The second link is actually Cisco's Product Visio Stencil spreadsheet.
http://www.cisco.com/en/US/products/hw/prod_cat_visios.html
http://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=3&ved=0CH8QFjAC&url=http%3A%2F%2Fwww.cisco.com%2Fen%2FUS%2Fprod%2Fassets%2Fvisio%2Fproduct_visio_icon0900aecd800940d9.xls&ei=wdzhT8iMDpD82gX_ysm_Cw&usg=AFQjCNEly70LnszNx59WA1a2TdtFY_Walg
You could use one of these and update the shape data properties to reflect '2OC3'.  The other option I can think of would be to try and create a custom shape for your needs.
http://www.techrepublic.com/article/get-it-done-create-your-own-custom-stencils-in-microsoft-visio/1058068
dgalati000
thanks,  yes, i have the others.  I will try two tacts:  create a low priority TAC case to get this from Cisco (if the stencil exists)...or just do Visio magic and just create the other two Tx and Rx ports on the existing one...thx.
That sounds like a good plan!  I'd be curious if TAC has it hidden somewhere.  Let us know what you find out!
Mastin
To go to TAC I hafta open a SR..which means I gotta go into the data center, get a s/n off one of the 7206's, open the SR, etc.  I just modified the 1 port OC3 SM stencil...it works for my objective.  IS there an 'attach' feature here ?  I'd attach the stencil if I could find that feature....thx.  Send me your email again and I'll send it that way >>  dg1318@att.com  <<
