Need example for setting up ACL for VLAN
edwincollins
I am needing to setup some ACL's on a 3560G switch Switch is running IOS). We want to restrict access to a VLAN to a select few IP addresses and ip address ranges, these would be inbound to the VLAN.
I could use examples of how best to do this.
Thanks and Regards
Edwin Collins
Reza Sharifi
Edwin,
You can use ACL to restrict access to the vlan.
have a look at the config guide with examples
http://www.cisco.com/en/US/docs/switches/lan/catalyst3560/software/release/12.2_25_se/configuration/guide/swacl.html
Reza
Ganesh Hariharan
Thanks and Regards
Edwin Collins
Hi Edwin,
Check out the below link aslo for basic concept for applying acl in switches/routers
http://www.cisco.com/en/US/products/sw/secursw/ps1018/products_tech_note09186a00800a5b9a.shtml
Hope to Help !!
Ganesh.H
Remember to rate the helpful post
