Need for 2 vlan to ping to each other
c.legault
On a 3750 I have configure a new vlan 114 and assigned it the adress 192.168.114.254, I've put  my port in trunk mode with with the other vlan wich is vlan 1 192.168.14.254. I would like for both network to ping each other, when I received a adress from the dchp I get 192.168.14.20/24 with the gateway 192.168.14.254
Thanks for your help
nspasov
You will need to setup SVIs (Switched Virtual Interfaces) or connect the switch to a router so traffic between the two VLANs can be routed. Take a look at the following link for more info/explanation:
http://www.cisco.com/c/en/us/td/docs/ios/12_2/switch/configuration/guide/fswtch_c/xcfvl.html
Thank you for rating useful posts!
Thank you for rating helpful posts!
Reza Sharifi
Did you add the helper-address command (DHCP) to vlan 114 SVI?
nspasov
