02-09-2011 10:36 PM - edited 03-06-2019 03:27 PM
I am trying to configure additional vlan's on my Cisco 871 Integrated Services Router by using the global configuration command vlan but I am not able to.
The following is the output from the show version command:
Router#show version
Cisco IOS Software, C870 Software (C870-ADVIPSERVICESK9-M), Version 12.4(6)T7, R
ELEASE SOFTWARE (fc5)
Copyright (c) 1986-2007 by Cisco Systems, Inc.
Compiled Thu 29-Mar-07 11:37 by khuie
ROM: System Bootstrap, Version 12.3(8r)YI3, RELEASE SOFTWARE
Router uptime is 5 hours, 58 minutes
System image file is "flash:c870-advipservicesk9-mz.124-6.T7.bin"
Cisco 871 (MPC8272) processor (revision 0x200) with 118784K/12288K bytes of memo
ry.
Processor board ID FHK111412ZX
MPC8272 CPU Rev: Part Number 0xC, Mask Number 0x10
5 FastEthernet interfaces
128K bytes of non-volatile configuration memory.
28672K bytes of processor board System flash (Intel Strataflash)
Router#
Solved! Go to Solution.
02-09-2011 10:41 PM
Hi Djuan,
In order to configure vlan on the router go under the vlan database from the neble mode and then congiure it.For ex:
router#vlan database
router#vlan 10
Hope the above helps.
Swati
Please rate if you find content useful
02-09-2011 10:41 PM
Hi Djuan,
router#vlan 10
Swati
02-09-2011 10:55 PM
Thank you. That worked.
Date: Wed, 9 Feb 2011 23:42:01 -0700
To: umarabd@hotmail.com
Subject: New message: "Need help configuring vlan's on a Cisco 871 Integrated Services Router"
DJUAN ABDULLAH,
A new message was posted in the Discussion thread "Need help configuring vlan's on a Cisco 871 Integrated Services Router":
https://supportforums.cisco.com/message/3290118#3290118
Author : Swati Dheer
Profile : https://supportforums.cisco.com/people/sdheer
Message:
