Need help getting to rommon prompt on Cat 2950
sklapper1
I'm trying to use Hyperterminal to get to the rommon prompt on a cat 2950, but can't seem to do it. I've been using Ctrl-Break, Break, Ctrl-F6-Break. But it keeps loading up without going into rommon. Can anyone please tell me the proper sequence to access rommon with the 2950? Thanks!
Steve
keeleym
Level 5
Level 5
Hi Steve
On the 2950 I think that you press the "Mode" button on the front when you power up the switch.
This should interrupt the boot sequence and leave you at a prompt that looks like
switch:
Have a look here http://www.cisco.com/en/US/products/hw/switches/ps628/products_password_recovery09186a0080094184.shtml
Best Regards,
Michael
