Need help in hardware solutions.
shala.arber
NM-2CE1T1-PRI is end of life and is replaced with HWIC-2CE1T1-PRI.
my router has all four slots populated with other interface cards.
i want to know if this HWIC-2CE1T1-PRI is compatible with the same slot as NM-2CE1T1-PRI or i won't have any more slots available for the new product????
i need this asap because i have to make an order. if i'm not clear enough please contact me by e-mail.
thank you very much.
andrew.prince
Level 10
Level 10
The HWIC-2CE1T1-PRI card is for the 2800 and the 3800 series router. So if your current platform is one of the above - it will be OK, see the below data sheets:-
http://www.cisco.com/en/US/products/ps5854/products_relevant_interfaces_and_modules.html
http://www.cisco.com/en/US/prod/collateral/modules/ps2797/product_data_sheet0900aecd80710c88_ps5949_Products_Data_Sheet.html
HTH>
