need help in switch 2960 telnet users!
Dr.X
Level 2
Level 2
heloo, i have a swich with a public ip , the problem that when i make a telnet connection , the switch tell me that the password not set, but im sure that the password is set.
when i type #sh users
i found the following:
    Line       User       Host(s)              Idle       Location
   1 vty 0                idle                    2d14h xxx.153.43.139
   2 vty 1                idle                 23:36:10 1xxxx8.79.2
   3 vty 2                idle                    1d22h xxx.79.2
   4 vty 3                idle                    1d21h xxxx.79.2
   *5 vty 4                idle                 22:47:25 xxxx.79.2
i dont know who are those users????that saturated my vty command 0 4 ???????????
the configurations are:
line con 0
exec-timeout 0 0
password 111
logging synchronous
login
line vty 0 4
exec-timeout 0 0
password 111
logging synchronous
login
line vty 5 15
login
end
can any one help me? yesterday i connected with it many times , but today i cant !!!!!!!
thanks alot
8 Replies 8
vipinrajrc
Level 3
Level 3
are you using telenet to access this switch using public?
from the configuration itself it is clear that you coonfigured telnet password for line vty 0 4.
line vty 0 4
exec-timeout 0 0
password 111.
But not configured for
line vty 5 15
login
From the show user it is clear that all the 5 terminals are occupied
lint vty 0 4 --> means five vty line.
for line vty 5 15 u didnt configured any password.
you can terminate the above conenctions....... by commands
please rate this post if it is helpful
thanks
vipin
Thanks and Regards, Vipin
you can remove the above sessions  by
no line vty
thnak you very much , but my question is that actually there are no 5 connections above !!!!!!!!! why they are existed wheni type sh users????????
i mean that actually no one is connecting to the switch usibng telnet but the sessions are existed !!!!!!!!!!!!!!!!!
can any 1 help me !?
it denied my command when i typed no line vty command
here is the result
xp10(config)#no line vty 1
% Can't delete last 16 VTY lines
xp10(config)#no line vty 2
Hello Ahmed,
It should say clear line vty, not no line vty - actually, the second one is dangerous as it may deconfigure your VTYs, disabling the possibility to connect remotely altogether.
The clear line vty is used in privileged EXEC mode, outside of the global config.
Best regards,
Peter
thanks very much all> i ve solved the problem now.
but now i want to know , why there were a useres that actually are not exist !!!! ???????
Hi Ahmed,
Try using the "clear line vty x" command from privileged exec to kick out those idle users.
Switch#clear line vty 0
Your Telnet users stayed with their remote session due to the "exec-timeout 0 0" command. Try to tweak this line to force logout idle session after X minutes.
I would recommend reserving one vty line for using an ACL to prevent yourself from being locked out.
access-list 1 permit
line vty 5
access-class 1 in
thanks very much , i doubted with it from the beginning.
