Need help! Serious problem with Cisco ME 3400 Switch
hardy
Hi everyone!
I have Cisco ME 3400 Switch that stopped working, when i tryed to connect to the console via Console Cable all i can get is this below.
- System lamp blinks constantly *from start.
- all 24 ports indicator lamps + 2 FSP ports lights up first Orange then Green about 5 sec and they turns off later.
- and that's it.
I wonder if you guys know what is the problem with my switch.
here is a short clip of it.
https://youtu.be/fUVAF8fRmDc
Leo Laohoo
Sounds like a dead switch.
Have you tried changing to a different baud rate of the console terminal?
hope not!
I have been testing 110, 300, 600, 1200, 2400, 4800, 9600 and 14400.
Is the same output if you go into rommon mode? otherwise you could try using this command:
rommon:1:flash_init
rommon2#set BAUD 9600
rommon3#reset
Please see the following link, It could be useful (without remove any file)
https://supportforums.cisco.com/discussion/11391726/3750-recovery-baud-setting
>> Marcar como útil o contestado, si la respuesta resolvió la duda, esto ayuda a futuras consultas de otros miembros de la comunidad. <<
