Need help to configure CA Signed Certificate on Cisco 2960X
vinod.tiwari16
I have multiple Cisco 2960X Switches and i want to configure CA Signed SSL Certificate on Switch but unable to configure the same..
Please help to get this configure..
Thank You
5 Replies 5
can you be more specific about where you get stuck ? Have you configured a CA Trustpoint ?
Post the config you have so far...
Also, refer to this document:
http://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst2960x/software/15-0_2_EX/security/configuration_guide/b_sec_152ex_2960-x_cg/b_sec_152ex_2960-x_cg_chapter_01010.html#d72206e292a1635
crypto pki trustpoint abc-xyz
 enrollment terminal pem
 usage ssl-server
 ip-address none
 subject-name CN=abc-xyz D=xx C=xx S=xxxx
 revocation-check crl
 eckeypair xx2017
 hash sha256
When i am exporting this to get signed by CA then i am getting below error:
Abc(config)#crypto pki export abc-xyz pem  terminal
% The specified trustpoint is not authenticated (abc-xyz).
Abc(config)#
Sorry for asking stupid questions, but did you authenticate with 'crypto pki authenticate' ?
Tried to Authenticate but it was asking for CA Server..
That was not getting connected.
Abc(config)#crypto pki authenticate abc-xyz
Enter the base 64 encoded CA certificate.
End with a blank line or the word "quit" on a line by itself
% Error processing Certificate Authority certificate.
Abc(config)#
So when you enter the command crypto pki authenticate you will need to paste the contents of the Root CA certificiate, this is the CA that is signing the certificate of the switch.
