Need help to console in Cisco Cat 5000 w/Sup I
centexlan2005
I really need help. Purchased used Cisco Catalyst 5000 with Supervisor 1 card. It has a db25 female connection to console in. I don't have the cable for it so I'm trying to make one. I already have the db25 (male)to rj45 adapter, a rollover cable, and db9 (female) to rj45. I want to use my older laptop which has db9 male port on it. Can I do this with these cables and adapters? Anyone can tell me the pin-outs for the adapters? Appreciate any help. My e-mail is centexlan@earthlink.net tel: (254)466-7242. Thanks.
BTW I found this link for Frye's Electronics which has this cable. Will this work?
http://shop3.outpost.com/product/1969412?site=sr:SEARCH:MAIN_RSLT_PG
I think you just need a straight cable to connect the DB25 to the DB9 on your PC.
Here are the pinouts (scroll down to Table D-1):
Connect a Terminal to the Catalyst 5500/5000 Supervisor Engine I and II Console Port
http://www.cisco.com/en/US/products/hw/switches/ps700/products_tech_note09186a008010ff7a.shtml#connectcat5000
HTH,
GP
Did you mean D-2? The D-1 table is for db-25(DCE) to db-25 (DTE). It looks like D-2 is the one. One last question.. I don't understand the xmit and send. Colors work better for me. Would you know this pin layout by colors?
