need help understanding ssh configuration to catalyst
TFP_Helpdesk
  i need to understand why my pc cannot connect to our catalyst 3850 while my ip address is 10.1.3.3 but i can when it's either 10.1.3.1 or .2 (it seems that no other pc can from the network 10.1.3.x with x>2). Config was done by somebody who has left the company.
  I'm rather new to ios so let me know if i missed anything from the config :
username admin privilege 15 password 7
no aaa new-model
switch 1 provision ws-c3850-48t
switch 2 provision ws-c3850-48t
ip ssh time-out 60
ip ssh authentication-retries 2
interface Loopback0
ip address 172.16.0.12 255.255.255.0
ip mtu 1500
line vty 0 4
login local
transport input ssh
line vty 5 15
login
ip route vrf Mgmt-vrf 0.0.0.0 0.0.0.0 172.16.0.254
SW-3850-01#sh version
Cisco IOS Software, IOS-XE Software, Catalyst L3 Switch Software (CAT3K_CAA-UNIVERSALK9-M), Version 03.03.01SE RELEASE SOFTWARE (fc1)
sorry i don't know how much is needed and how much config i cannot give to avoid troubles.
Thanks in advance
Jerome
15 Replies 15
Francesco Molino
Can you do on the switch the following commands and paste it into a text file?
- show run | sec line
- show access-list
- show run | sec control-plane
Francesco
PS: Please don't forget to rate and select as validated answer if this answered your question
SW-3850-01#show run | sec line
line con 0
login local
stopbits 1
line aux 0
stopbits 1
line vty 0 4
login local
transport input ssh
line vty 5 15
login
SW-3850-01#show access-list
Extended IP access list preauth_ipv4_acl (per-user)
10 permit udp any any eq domain
20 permit tcp any any eq domain
30 permit udp any eq bootps any
40 permit udp any any eq bootpc
50 permit udp any eq bootpc any
60 deny ip any any
IPv6 access list preauth_ipv6_acl (per-user)
permit udp any any eq domain sequence 10
permit tcp any any eq domain sequence 20
permit icmp any any nd-ns sequence 30
permit icmp any any nd-na sequence 40
permit icmp any any router-solicitation sequence 50
permit icmp any any router-advertisement sequence 60
permit icmp any any redirect sequence 70
permit udp any eq 547 any eq 546 sequence 80
permit udp any eq 546 any eq 547 sequence 90
deny ipv6 any any sequence 100
SW-3850-01#show run | sec control-plane
SW-3850-01#
There is nothing blocking.
Can you share the complete config? (remove all passwords). Please attach a text file and not pasting the complete config.
Can you run a debug ip ssh while trying to access the switch in ssh from a non working client?
Which kind of error are you getting on the client when trying to access ssh?
Francesco
files attached, for info we have 2 3850 in stacks connected to 2 4500x.
when trying from a non working ip we get no message, not even a ping reply which does make me believe that it's a permit list of some sort but i cannot find any restriction
debug ip ssh show no display during tries, putty terminate connection with timeout.
would it be the 4500x that block the connections attempts ?
Who is IP 10.99.99.2? Can you paste the config?
From a working client, can you do a traceroute 172.16.0.12?
Francesco
10.99.99.2 is our internal interface for sophos firewall stack.
traceroute from working client :
>tracert 172.16.0.12
Tracing route to 172.16.0.12 over a maximum of 30 hops
1 4 ms 6 ms 3 ms sw-4500x-01 [10.1.3.254]
2 16 ms 11 ms 18 ms 172.16.0.12
Trace complete.
from a non working client :
H:\>tracert 172.16.0.12
1 <1 ms 1 ms <1 ms sw-4500x-01 10.1.3.254
2 * * * Request timed out.
3 * * * Request timed out.
i
Ok.
From your 4500, can you do the following commands:
- sh ip route 172.16.0.0
- sh ip arp | i 172.16.0.
on your 3850:
- sh ip route 10.1.3.0
On your client (working):
- give me the output of its routing table
Same on your non working client --> output of routing table
On your Sophos Antivirus, can you validate that non working is blocked by your firewall?
Francesco
SW-4500X-01#sh ip route 172.16.0.0
Routing entry for 172.16.0.0/16, 26 known subnets
Attached (26 connections)
Variably subnetted with 2 masks
C 172.16.0.0/24 is directly connected, Vlan1720
L 172.16.0.254/32 is directly connected, Vlan1720
will put arp in a file attached, regarding the route well it's quite straight forward :
IPv4 Route Table
Active Routes:
Network Destination Netmask Gateway Interface Metric
0.0.0.0 0.0.0.0 10.1.3.254 10.1.3.83 266
10.1.3.0 255.255.255.0 On-link 10.1.3.83 266
10.1.3.83 255.255.255.255 On-link 10.1.3.83 266
10.1.3.255 255.255.255.255 On-link 10.1.3.83 266
127.0.0.0 255.0.0.0 On-link 127.0.0.1 306
127.0.0.1 255.255.255.255 On-link 127.0.0.1 306
127.255.255.255 255.255.255.255 On-link 127.0.0.1 306
224.0.0.0 240.0.0.0 On-link 127.0.0.1 306
224.0.0.0 240.0.0.0 On-link 10.1.3.83 266
255.255.255.255 255.255.255.255 On-link 127.0.0.1 306
255.255.255.255 255.255.255.255 On-link 10.1.3.83 266
Persistent Routes:
Network Address Netmask Gateway Address Metric
0.0.0.0 0.0.0.0 10.1.3.254 Default
the crazy part for me is it all seems to be the origin IP that cause this, as i say if i change the ip on my machine i can connect. My original statement to say no ip on 10.1.3.x work is apparently quite wrong as i found out this :
working not working
1 3
2 4
5 7
6 9
8 11
10 12
13 15
14 17
16 18
19 83
85 84
86 87
96 88
94
most of them having been tested by changing the ip on the same machine and doing a ping and a putty test. i almost saw a pattern at start that 2 work, 2 not work etc but this was blown later.
Nothing make sense anymore. there is no blockage on the firewall, the traffic shouldn't even go through it as far as i know unless it goes outside the network. 4500x act as our core gateway
Hello
In relation to your pc and this switch stack what is the physcial topology.
Are you traversing other devices before hitting the stack?
This seems to suggest a ACL or policy restriction.
res
Paul
Kind Regards
Paul
We have a layer 2 network full of cisco meraki switches while using vlans.
as i discovered in a post above is actually worse than i thought and almost half of the range 10.1.3.x is accessing while other is not without much logic to it.
Can you run a ping to your 3850 ip from a non working station and working station? While the ping runs, can you do a debug ip icmp on your 3850?
Francesco
soo
i see no output whatsoever with the debug ip icmp while connected through putty while both ping -t are running
i'm starting to think the problem may be with how the ssh has been configured and/or connected to the network (management port connected to one of the meraki switch) if that make sense
Hello
 "thought and almost half of the range 10.1.3.x is accessing while other is not"
Can you confirm the subnet mask for this range for this correct on the rtr or l3 switch and it isnt mis-configured?
res
Paul
Kind Regards
Paul
