Need help using RIP connecting two networks with two routers in Packet Tracer
michaelrjonas
Hello and thanks for reading if you can,
I am working on an assignment that requires two groups of hosts to be connected across two routers using RIP and not static routing.
The simulation is in packet tracer.
I used RIP with all directly connected networks on both routers. At one point, I can ping from the wirelessly connected laptops to the desktop PCs, but not the other way around. I know I could fix this easily with static routing but the assignment is to use RIP only.
Can somebody help explain to me how I would route these two networks using RIP only?
I am a newbie at this working on my CCENT so any help greatly appreciated!
Mike
18 Replies 18
Hello
I realised the firewall would have been blocking this and traffic outbound would have been NAT'd, hence the successful ICMPs.
Turning the firewall off or doing port forwarding, it still means we will have to put a 192.168.0.0 route out there somehow, and the only way to do this is static routing.
Michael, in this case I think you have done everything you can. The only thing that remains is connectivity to the laptops from PCs, which we can achieve, but isn't required in this assignment.
Hope this helps
Please rate useful posts & remember to mark any solved questions as answered. Thank you.
in the requirements posted by the OP I don't see you must be able to ping from the desktop to the wireless laptop and it is supposed to  have a private IP and seat behind a firewall router doing NAT so it wouldn't make sense having a static route for this subnet unless you wanted to do a site-to-site IPSec VPN.
Alain
This scenario was about completing the tasks in the assignment. Please review the whole thread and see posts 9 and 10 I believe. He did mention in his original post that he couldn't ping from PCs to laptops.
Michael has done what he can to complete this and his configurations are correct. Just the 10.x.x.x network that remains
I never said he hadn't completed the tasks nor that his configs are incorrect , I said that reading the assignement I never saw he had to ping from the desktops to the wireless laptops so why bother about it as he can ping from the laptops to the desktops.
