Need Help with inter Vlan routing
wfirth2012
Current configuration : 6441 bytes
! Last configuration change at 00:49:49 UTC Mon Mar 1 1993
version 15.0
no service pad
hostname Switch
boot-start-marker
boot-end-marker
no aaa new-model
switch 3 provision ws-c3750v2-48ps
system mtu routing 1500
vtp mode transparent
ip routing
crypto pki trustpoint TP-self-signed-2439348352
enrollment selfsigned
subject-name cn=IOS-Self-Signed-Certificate-2439348352
revocation-check none
rsakeypair TP-self-signed-2439348352
crypto pki certificate chain TP-self-signed-2439348352
certificate self-signed 01
3082022B 30820194 A0030201 02020101 300D0609 2A864886 F70D0101 05050030
31312F30 2D060355 04031326 494F532D 53656C66 2D536967 6E65642D 43657274
69666963 6174652D 32343339 33343833 3532301E 170D3933 30333031 30303032
35345A17 0D323030 31303130 30303030 305A3031 312F302D 06035504 03132649
4F532D53 656C662D 5369676E 65642D43 65727469 66696361 74652D32 34333933
34383335 3230819F 300D0609 2A864886 F70D0101 01050003 818D0030 81890281
8100D494 95DD9564 CAB3651B 80B2B619 C6CDC868 F1958723 D883F0BA 97E783F6
42C1954E 99A26BC4 82B901CE BE36B1E4 4CCC63B5 03D11257 50B95E21 3EE56F6B
E0E40966 19185F64 6A843DBF 62247EE7 9DBAF33F 48D239F6 34B0C497 8E86D092
78E4C3E1 D7DB4F5F 656FA734 58EAA49D FA2F218B 02F1B51C 74C15A17 E2E7078A
D50D0203 010001A3 53305130 0F060355 1D130101 FF040530 030101FF 301F0603
551D2304 18301680 141F4EF6 5795B0BA 6FCA1621 7AD03019 711C2892 C6301D06
03551D0E 04160414 1F4EF657 95B0BA6F CA16217A D0301971 1C2892C6 300D0609
2A864886 F70D0101 05050003 8181000D F3D09FF4 4A45A981 1898C68A A7AF6265
F775B06C AFD504BB 0AB5435E A0A3160C DCFACED9 89080B4C F41A1F93 64978CB4
7205E3AA B201685F 7042DED2 6F9F506E 668D0389 7D8CF4D5 A6DFA81B B3551C26
4DC5BA91 D8CE74F3 B23F4B44 16F05759 FA8813F4 C6641C80 DBC1596D 01CCD5FC
4BA6E1AD EBB435CF 6571E45D 087C3C
quit
spanning-tree mode pvst
vlan internal allocation policy ascending
vlan 2-3,10
interface FastEthernet3/0/1
switchport access vlan 2
switchport mode access
interface FastEthernet3/0/2
interface FastEthernet3/0/3
interface FastEthernet3/0/4
interface FastEthernet3/0/5
interface FastEthernet3/0/6
interface FastEthernet3/0/7
interface FastEthernet3/0/8
interface FastEthernet3/0/9
interface FastEthernet3/0/10
interface FastEthernet3/0/11
interface FastEthernet3/0/12
interface FastEthernet3/0/13
interface FastEthernet3/0/14
interface FastEthernet3/0/15
interface FastEthernet3/0/16
interface FastEthernet3/0/17
interface FastEthernet3/0/18
interface FastEthernet3/0/19
interface FastEthernet3/0/20
interface FastEthernet3/0/21
switchport access vlan 3
interface FastEthernet3/0/22
interface FastEthernet3/0/23
interface FastEthernet3/0/24
interface FastEthernet3/0/25
interface FastEthernet3/0/26
interface FastEthernet3/0/27
interface FastEthernet3/0/28
interface FastEthernet3/0/29
interface FastEthernet3/0/30
interface FastEthernet3/0/31
interface FastEthernet3/0/32
interface FastEthernet3/0/33
interface FastEthernet3/0/34
interface FastEthernet3/0/35
switchport access vlan 10
interface FastEthernet3/0/36
interface FastEthernet3/0/37
interface FastEthernet3/0/38
interface FastEthernet3/0/39
interface FastEthernet3/0/40
interface FastEthernet3/0/41
interface FastEthernet3/0/42
interface FastEthernet3/0/43
interface FastEthernet3/0/44
interface FastEthernet3/0/45
interface FastEthernet3/0/46
interface FastEthernet3/0/47
interface FastEthernet3/0/48
interface GigabitEthernet3/0/1
interface GigabitEthernet3/0/2
interface GigabitEthernet3/0/3
interface GigabitEthernet3/0/4
interface Vlan1
no ip address
interface Vlan2
ip address 10.1.2.1 255.255.255.0
interface Vlan3
ip address 10.1.3.1 255.255.255.0
interface Vlan10
ip address 10.1.4.1 255.255.255.0
ip http server
ip http secure-server
line con 0
line vty 0 4
login
line vty 5 15
login
end
Hello im trying to ping each VLAN however i cant im not sure what im m
Hi @wfirth2012
 It should work.  The switch is properly configured with "ip routing" command.
How are you testing?
You need to put one PC on Vlan 2, for example, and another PC on vlan 3.  Both PC need to have default gateway pointing to its respective VLan IP address.
Hi, im not able to ping the vlans? im only using a switch with no PC's connected
Can you share the command  "ipconfig"  on the PC side, if you are using Windows?
And tell me in which port it is connected ?
wfirth2012
Hi i have sorted it now, thankyou for the help
