Need help with setting up vlan trunk
linuxmad1
Hi everyone,
I have a slm224g and just bought a slm2008 and i want to setup a trunk between the too switches so then vlan 10, 20 ,30 can communicate with the vlan 10, 20 ,30 on the another and i can not work out how to do it
Any help/guidance on this will be great
linuxmad1
Just a update, i have done it and its working great
Hi Paul!
Can You describe how You doing a trunk link? I have a problem with set up trunk to routers, which must route different VLANs.
I describe my problem here: https://supportforums.cisco.com/thread/2057413?tstart=0
Just look to my steps if possible.
Thanks in advance!
