ASA/SubInterfaces/VLAN/Trunking Question
losbanosit
Community Member
I currently have a 3750 connected to my ASA 5520 on the "inside" interface.  I would like to introduce 2 subinterfaces on the ASA "inside" interface and trunk the switchport.  I believe I have done this, but I am not able to ping from the ASA to a client computer on a new vlan off a downstream switch.  Here is what I have.  ASA interface is 192.168.52.1 --> Cisco 3750 is 192.168.52.248 --> Cisco 2960 is 192.168.52.249 --> Cisco 2950 is 192.168.52.250.  I created the VLANs with 192.168.20.1(VLAN20) and 192.168.30.1(VLAN30), these are showing up on all three switches and I am able to PING between all switches.  I cannot get outside to the internet, and also I cannot ping the subinterface IPs that I created on the ASA (192.168.20.1 and 192.168.30.1).
I trunked the swithport that goes up to the ASA, but the configuration is as follows:
interface GigabitEthernet1/0/2
switchport access vlan 3
switchport mode access
spanning-tree portfast
I believe my problem is with a misconfiguration on the Gig 1/0/2 interface.  Please confirm what my configuration would have to be in order to maintain the
original traffic, and introduce the new networks (192.168.20.X and 192.168.30.X).  What do I have wrong here?
The help from the community is appreactiated!!
JG
Reza Sharifi
Your switch port is not trunked
configure the 3750 as follows and try again
switchport trunk allowed vlan 20,30
switchport mode trunk
end
C3750-E(config-if)#
Reza
7 Replies 7
Reza Sharifi
end
C3750-E(config-if)#
Reza
Perfect, thanks for the reply.
Will this still allow the native (not sure how to reference it) or VLAN3 (192.168.52.X) traffic to continue to pass?  The new networks are intended to be my "test" environments, while the production network is actually on that interface as 192.168.52.1 currently.  I was reading about the "nameif" command and got a little confused.
I knew something looked strange about that configuration
Thanks Reza,
JG
If you want to use vlan 3 as native vlan, you can add it to the config.  see below:
Current configuration : 168 bytes
switchport trunk native vlan 3
end
C3750-E(config-if)#
If I run the commands in the following manner, will I have any network downtime or outage?  I'd like to do this ASAP....
conf t
int gig1/0/2
wr mem
Just curious if I have all the commands in order to complete this.
The above should take my current config of:
To:
Correct?
JG
I would do it during an outage window.  That will give you also sometimes to test it to make sure every thing is working
I agree, but there is ALWAYS someone "in the office" around here!
Thanks for your time and input.  I'll post my results in hopes it can help someone else with a similar configuration issue.
JG
Just to follow up, the configuration that Reza recommended worked perfectly.  I now am able to see all
traffic between the firewall and the switches.
Thank you for your time Reza!
JG
