need help with this Cisco 2911 - attach sh run
m-abooali
Level 4
Level 4
Hi Folks,
 First Time on Cisco 2911 Router.
I am trying to replace a Cisco 3550 SW with this Cisco 2911. it seems that I need to SW module to create VLANs and SVIs. I have given IP add to embadded-service-Eng 0/0 and no shut however, I cannot login to the sw module as I get the router prompt when I try.
This router doesn't have EHIWIC at all but three GI interfaces 0/0, 0/1 and 0/2
My 3550 SW have two vlans and SVIs and connects to provider and from inside connect to a Sonicwall FW. I though it would be matter of configuring gi0/0 and Gi0/1 on this router and router should do what this SW3550 has been doing. just to connect us to the provider. no fancy configurations. Please advise,
i cannot upload a text file so I pate it here:
=~=~=~=~=~=~=~=~=~=~=~= PuTTY log 2018.08.02 13:32:22 =~=~=~=~=~=~=~=~=~=~=~=
sh ver
Cisco IOS Software, C2900 Software (C2900-UNIVERSALK9-M), Version 15.5(3)M7, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2018 by Cisco Systems, Inc.
Compiled Mon 05-Feb-18 10:16 by prod_rel_team
ROM: System Bootstrap, Version 15.0(1r)M15, RELEASE SOFTWARE (fc1)
Router uptime is 30 minutes
System image file is "flash0:c2900-universalk9-mz.SPA.155-3.M7.bin"
Last reload type: Normal Reload
Last reload reason: power-on
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
Cisco CISCO2911/K9 (revision 1.0) with 1011712K/36864K bytes of memory.
Processor board ID FTX1604AJMA
3 Gigabit Ethernet interfaces
1 terminal line
DRAM configuration is 64 bits wide with parity enabled.
255K bytes of non-volatile configuration memory.
250880K bytes of ATA System CompactFlash 0 (Read/Write)
License Info:
License UDI:
Device#      PID            SN
*1        CISCO2911/K9          FTX1604AJMA
Suite License Information for Module:'c2900'
Suite                 Suite Current         Type           Suite Next reboot
FoundationSuiteK9     None                  None           None
securityk9
datak9
AdvUCSuiteK9          None                  None           None
uck9
cme-srst
cube
Technology Package License Information for Module:'c2900'
Technology    Technology-package                  Technology-package
              Current              Type           Next reboot
ipbase        ipbasek9             Permanent      ipbasek9
security      None                 None           None
uc            None                 None           None
data          datak9               RightToUse     datak9
Router#term len 0
Router#sh run
Building configuration...
Current configuration : 1207 bytes
! Last configuration change at 17:11:12 UTC Thu Aug 2 2018
version 15.5
hostname Router
boot-start-marker
boot-end-marker
no aaa new-model
ethernet lmi ce
ip cef
no ipv6 cef
license udi pid CISCO2911/K9 sn FTX1604AJMA
license accept end user agreement
license boot module c2900 technology-package datak9
redundancy
interface Embedded-Service-Engine0/0
 ip address 10.10.10.1 255.255.255.0
interface GigabitEthernet0/0
 no ip address
 shutdown
 duplex full
 speed 100
interface GigabitEthernet0/1
 no ip address
 duplex auto
 speed auto
interface GigabitEthernet0/2
 no ip address
 shutdown
 duplex auto
 speed auto
ip forward-protocol nd
no ip http server
no ip http secure-server
control-plane
 vstack
line con 0
line aux 0
line 2
 no activation-character
 no exec
 transport preferred none
 transport output lat pad telnet rlogin lapb-ta mop udptn v120 ssh
 stopbits 1
line vty 0 4
 login
 transport input none
scheduler allocate 20000 1000
end
Router#
Best Regards,
Masood
m-abooali
Level 4
Level 4
Ok, This is what I have done: I followed the 2900 series configuration Guide.
XXXXXX#sh ip int bri
Interface                  IP-Address      OK? Method Status                Protocol
Embedded-Service-Engine0/0 unassigned      YES manual administratively down down
GigabitEthernet0/0         x.x.x.22    YES manual down                  down========================>>>Connectes to provider on a Ether Ckt 100 mb
GigabitEthernet0/1         x.x.x.129    YES manual down                  down ========================>>>INside LAN
GigabitEthernet0/2         unassigned      YES unset  administratively down down
Loopback0                  10.10.10.10     YES manual up                    up ============>lookbak
UTP-2911-BR1#
UTP-2911-BR1#conf t
Enter configuration commands, one per line.  End with CNTL/Z.
UTP-2911-BR1(config)#int gi 0/0
UTP-2911-BR1(config-if)#port-
UTP-2911-BR1(config-if)#port-tagging ?
  <cr>
UTP-2911-BR1(config-if-port-tagging)#encap
UTP-2911-BR1(config-if-port-tagging)#encapsulation dot1q ?
  <1-4094>  VLAN id
UTP-2911-BR1(config-if-port-tagging)#encapsulation dot1q 231 ?
  <cr>
Any Thoughts?
Best Regards,
Masood
