Need help with Vlan switching & Ospf assignment
Vishnu
Also sorry, english isn't my native language so I tried to translate the assignment as best as I could.
I only managed to do the DHCP server & I am not sure if I did it correctly or not. Because I tried other things like doing the ethernet channel but then the cable indicators started flickering green & it stopped working at all, so I reverted the file back to the original to only the DHCP server configuration. I am not sure about any of the stuff happening, like I know theoretically but what it should as I don't know the configuration. Would anyone be kind to explain how to configure it, for this exact example? I hope it is understandable from the topology provided in the image.  I would be so grateful to have an answer for this topology.
Link if anyone can access it:        https://drive.google.com/file/d/1NFnfGvu0TecXCKSrZyNRU5-yXTHLyetZ/view?usp=sharing
8 Replies 8
M02@rt37
regarding the picture, DHCP server seems to not have IP address and/or Router's 1 interface facing that DHCP server too....
Also, an issue on your serial lin between Router0 and Router2.
What is your exact issue ? Thanks for clarification.
Best regards
when I try to fix the problem like for each one of the routers like internet is on
150.150.150.128/29 (subnet mask of 255.255.255.248)
& the other ones such as the
NAT border router
PAT 150.150.150.129
SNAT 150.150.150.130 DMZ acts for Router0
Router 1 for Server0,
Server DMZ 5.5.5.5 (prefix /21)
Router 2 for Router on a stick DHCP server for VLAN 10,20,30
Etherchannel Spanning tree for Switches 0, 1 & 2
Network: 192.168.16.0/20
VLAN 10 Students  200 endpoints
ACL restricts communication between VLAN 10 and 20
VLAN 20 Teachers 100 endpoints
VLAN 30 THP 50 endpoints
Switches G0/1,G0/2,Fa0/1-Fa0/4 spine
Fa0/5-Fa0/14 first VLAN
Fa0/15-Fa0/24 second VLAN
VLAN 99 Management VLAN for SVI
VLAN 200 native VLAN for trunk ports
once all done its just SSH for routers and switches
hello @Vishnu . I can configure ur entire topology if u'd like.just let me know
more Cisco?!
more Gym?!
yes, @Enes Simnica can u configure the entire topology, & here's the link to the file:                      https://drive.google.com/file/d/1NFnfGvu0TecXCKSrZyNRU5-yXTHLyetZ/view?usp=sharing
Vishnu
@Enes Simnica you can configure my entire topology, right now.
Enes Simnica
for sure. will finish this meeting that im in first, and ill do that after..
more Cisco?!
more Gym?!
alright, & @Enes Simnica have you figured this topology out yet the image I sent in the private message, its in the packet tracer file google drive link.
hello my man @Vishnu
Just wrapped up some long, long outages and despite that, I was able to deal with your entire topology in about 4 minutes total.
so what i fixed:
  • Cleaned up all switch configs: removed bad lines, added missing interface and EtherChannel settings.
  • Corrected VLAN assignments, trunking, and port-channels (some were mismatched or suspended).
  • Fixed OSPF, so now routers now exchange routes properly.
  • Repaired DHCP on Router2 and VLANs 10, 20, and 30 now get IPs.
  • ACLs are working to restrict communication between VLAN 10 (Students) and VLAN 20 (Teachers).
  • Verified inter-VLAN routing and full Layer 3 connectivity, for sure all ping tests now succeed.
BUT - THere is something critical and BIG that i have for u. I FOUND A LAYER 2 LOOP on the lab.
So shere was a serious L2 loop between Switch0 and Switch2, causing major instability and likely broadcast storms.
The cause was misconfigured EtherChannel and STP not blocking redundant links correctly. I quickly localized the loop and shut down interfaces Fa0/1 and Fa0/2 on Switch0 to stabilize the network. AND here is the trick, I left those interfaces shut down on purpose (check the screenshot), cause this is ur chance to learn from a real-world scenario. ALso i will give u some hints: check the stp bridge roles and port states. Verify etherchannel config on both ends, and consider which switch is the root bridge, and whether it should be or not.... (Trust me u'll learn a lot from layer 2 loops, u will have fun....)
Meaning, 99.9% of the job done, the last 0.1% is for u my G. This is exactly the kind of situation that teaches u how small misconfigs can cause massive issues at Layer 2.
hope it helps G
-Enes
more Cisco?!
more Gym?!
