Need help with VLANs and Access Lists
Kevin Cummins
Hello.
Thanks to the people in this forum, I was able to get inter-vlan routing working.
Now, I have a different issue.
I have 3 VLANs now, but I need to prevent VLAN2 from accessing servers on VLAN1, but still be able to get to the internet.
The problem is that VLAN1 also contains the default gateway. When I tried to create an access list, it shuts off all connections from VLAN2 to the internet in addition to the other VLANs.
What should I do? If I could even just block specific IP addresses on the other VLANs, that would be sufficient. [I can't move the servers to another VLAN at this point] (Sample config below of what I tried to do. This is a router config, and 3 Catalyst 2960 switches are connected on ports 2,3, and 4)
interface FastEthernet0
no ip address
ip nat outside
ip virtual-reassembly
duplex auto
speed auto
pppoe enable
pppoe-client dial-pool-number 1
no cdp enable
interface FastEthernet1
no ip address
duplex auto
speed auto
interface BRI0
no ip address
encapsulation hdlc
shutdown
no cdp enable
interface FastEthernet2
switchport mode trunk
interface FastEthernet3
interface FastEthernet4
interface FastEthernet5
interface FastEthernet6
interface FastEthernet7
interface FastEthernet8
no cdp enable
interface FastEthernet9
no cdp enable
interface Dot11Radio0
no ip address
shutdown
speed basic-1.0 basic-2.0 basic-5.5 6.0 9.0 basic-11.0 12.0 18.0 24.0 36.0 48.0 54.0
station-role root
interface Dot11Radio1
no ip address
shutdown
speed basic-6.0 9.0 basic-12.0 18.0 basic-24.0 36.0 48.0 54.0
station-role root
interface Virtual-Template100 type tunnel
ip unnumbered Dialer1
tunnel mode ipsec ipv4
tunnel protection ipsec profile DYNAMIC-IPSEC-PROFILE
interface Vlan1
description VLAN for Internal Systems
ip address 10.10.33.1 255.255.255.0
ip nat inside
ip tcp adjust-mss 1414
interface Vlan2
description VLAN for Security
ip address 10.10.34.1 255.255.255.0
ip nat inside
ip access-group 170 out
interface Vlan3
description VLAN for Wireless
ip address 10.10.35.1 255.255.255.0
ip nat inside
interface Dialer1
description Connected to WAN
mtu 1454
ip address negotiated
ip nat outside
encapsulation ppp
no ip route-cache cef
no ip route-cache
no ip mroute-cache
dialer pool 1
dialer-group 1
no cdp enable
ppp authentication pap callin
ppp chap refuse
ppp pap sent-username xxxxxxxxxxxxxxxxxxxx
ip local pool xxxxxxxx-REMOTE-VPN-POOL 10.10.100.0 10.10.100.254
ip route 0.0.0.0 0.0.0.0 Dialer1 permanent
no ip http server
no ip http secure-server
ip nat inside source list 150 interface Dialer1 overload
ip nat inside source list 170 interface Dialer1 overload
ip nat inside source list 180 interface Dialer1 overload
ip access-list extended VPN-SPLIT-TUNNELS
remark ACL for VPN client split tunnel networks
permit ip 10.10.33.0 0.0.0.255 any
access-list 140 permit tcp host xxx.xxx.xxx.xxx any eq 22
access-list 150 permit ip 10.10.33.0 0.0.0.255 any
access-list 150 deny   ip 10.10.33.0 0.0.0.255 10.10.100.0 0.0.0.255
access-list 150 permit ip 10.10.33.0 0.0.0.255 10.10.34.0 0.0.0.255
access-list 160 permit ip 10.10.33.0 0.0.0.255 10.10.100.0 0.0.0.255
access-list 170 deny   ip 10.10.34.0 0.0.0.255 10.10.33.0 0.0.0.255
access-list 170 deny   ip 10.10.34.0 0.0.0.255 10.10.35.0 0.0.0.255
access-list 170 permit ip 10.10.34.0 0.0.0.255 any
   Do you want to block VLAN2 from accessing VLAN1? If so, just try this.
ip access-list extend Deny-VL2-To-VL1
permit ip any any
interface vlan 2
no ip access-group 170 out
ip access-group Deny-VL2-To-VL1 in
HTH,
Toshi
5 Replies 5
permit ip any any
interface vlan 2
HTH,
Toshi
Thank you for the reply. I will try it.
Will this still allow me to have internet access? The router/default gateway for the network is on VLAN1 (10.10.33.1). All internet traffic is going through this router.......
Also, I forgot to mention that the 3 switches have ip addresses of 10.10.33.2, 10.10.33.3, and 10.10.10.34.
   That ACL is used to block VLAN2 from accessing VLAN1. Anything else would be fine.
HTH,
Toshi
Do you want vlan2 to manage those 3 IP addresses?
Toshi
Thanks.
It worked.
But when i tried to take out the other access list from the config (access-list 170) it all stopped working. Weird.
Anyway, I'm happy. I can get internet access, and access to VLAN1 is blocked.
Thanks again.
