Need IOS to Support IPv6 for 3550/24 in-line power
clementsdi
Anyone know what IOS I can use that supports IPv6 for my 3550/24 in-line power switches....Thks....
Hi ,
Please mark this thread resolved so that other's can benefit.
~JG
Jagdeep Gambhir
Level 10
Level 10
IPv6 is not supported on the 3550 switches.
Please check this document for additional
information:
http://www.cisco.com/en/US/products/hw/switches/ps646/prod_eol_notice0900aec
d8029f777.html
Here is the list,
Catalyst 2900 series: Non-Compliant
Catalyst 3524: Non-Compliant
Catalyst 3508: Non-Compliant
Catalyst 3550 series: Non-Compliant
Catalyst 3560 series: Supported using Advanced IP Services IOS
Catalyst 3750 series: Supported using Advanced IP Services IOS
~JG
Please rate if helps
Hi ,
~JG
