Need logging from previous says on a verfy chatty router
CiscoBrownBelt
Level 6
Level 6
My log buffer is 300000 bytes and would like to know a good configuration so I can see logs from previous days (at least a week ago) however the problem is there is a lot of log events due to denied ACL hits. Anyone have a good reccomendation?
5 Replies 5
Julio E. Moisa
Unfortunately I think that is not possible unless you have a Syslog server or a Cisco ACS where the events are stored.
>> Marcar como útil o contestado, si la respuesta resolvió la duda, esto ayuda a futuras consultas de otros miembros de la comunidad. <<
Yes we do have a sys log server but I am not sure what events or info we are logging and why we are logging everything as well directly on the physical devices...new guy here.
Philip D'Ath
You'll need a seperate syslog server to do this.
That info could be seen through the logging commands, also I always suggest configure the following commands on the devices to know who is configuring and what:
archive
log config
logging enable
logging size 300
notify syslog contenttype plaintext
hidekeys
