Need solution to connect two LANs. Please help.
borgo2007
I would connect two networks separated by a private road with a 100Mb cable. (At the moment I can't use another cable)
Whichis the best solution ?
Here is the configuration:
Network-A
192.1.1.0
255.255.255.0
Network-B
192.2.0.0
255.255.255.0
Internet Gateway (it's on Network-B)
192.2.0.251
255.255.255.0
Clients from Network A should use the internet connection (smtp, pop3, http) provided by the adsl Router 192.2.0.252 (which
is on the Network-B)
All the other traffic between the Network A and Network B should blocked.
What I need to o it ?
1) My idea is:
---------BUILDING-1---------------STREET------------------BUILDING-2-------------------------------
Network-A <--> Router-A <--> BACKBONE CABLE <--> Roouter-B <--> Network-B <--> Gateway (Adsl Router)
Is it correct ? I like Cisco products, so which type of routers should I brought ?
Do the routers need two Ethernet interfaces or one is enough ?
ahmednaas
Level 4
Level 4
How big are networks A & B? What type of switches do you have now?
If you have cisco switches Then you could do it without adding routers:
Switch_A(VLAN 10)<--road--->ADSL router(Cisco 877)<-->Switch_B(VLAN 20). Notice that both switches are connected directly to the router, which has a 4 port switch.
On network A I have 10 pc
On network B I have 30 pc
The Adsl router is on network B and I need to use the internet connection through the network A.
I prefer a router solution than VLAN.
Now the two networks are connected by an ethernet cable with two switchs at the edge.
I I need to buy a router which is flexible, so when I'll change the backbone cable with a wireless link I can use it too.
Thank you for attention and greetings from Italy
Andrea
