Need switch part number (Throughput must be 3.4 Tbps Minimum or Higher)
md__shamsuddoha
I am searching cisco Nexus switch which Throughput must be 3.4 Tbps Minimum or Higher also rack mountable 1 or 2 U size.
Please help me for finding this type of switch
No there not below your requirement its in the link I posted there's 1 there thats supporting 3.6TB throughput , there's probably others if you look through the individual links for each platform
Nexus 9300 40GE Switches
Nexus 9332PQ Nexus 9336PQ Nexus 93180LC-EX
Usage ACI leaf, top of rack, end of row, FEX aggregation ACI spine ACI Leaf*, powered by Cloud Scale
Form factor 1 RU 2 RU 1 RU
Throughput (Tbps) 2.56 2.88 3.6
Nexus 93180LC-EX
5 Replies 5
Mark Malone
I would think you need to aim maybe for 9ks , this link you can see what they all support in throughput as example form below , you may struggle to find a 1 or 2 u that supports that though , I see 93s are just under it
http://www.cisco.com/c/en/us/products/switches/nexus-9000-series-switches/models-comparison.html
Nexus 9500 Chassis
Cisco Nexus 9504 Switch Cisco Nexus 9508 Switch Cisco Nexus 9516 Switch
Form factor 7 RU 13 RU 21 RU
Line card slots 4 8 16
Supervisor slots 2 2 2
Fabric module slots 6 6 6
ACI support Yes Yes Yes
Bandwidth per slot (Tbps) 3.84 3.84 3.84
Bandwidth per system (Tbps) 15 30 60
Maximum number of 1/10G BASE-T ports 192 384 768
Maximum number of 10 GE ports 576 1152 2304
Maximum number of 40 GE ports 144 288 576
Maximum number of 100GE ports 128 288 128
Airflow Front to back Front to back Front to back
Power supplies (3-kW AC/DC) Up to 4 Up to 8 Up to 10
Fan trays 3 3 3
Dear Mark Malone,
Thank you for replay.
i must need to fulfill below criteria
1.Throughput must be 3.4 Tbps Minimum or Higher
2.rack mountable 1U or 2U size.
9000 series Throughput below from my requirement.
thanks
shuvo
Nexus 93180LC-EX
thanks
Your requirement is not clear.  Do you need this switch for a data center or campus environment? If it is data center than the 9300 maybe sufficient but we still don't know how many ports (copper or fiber) you need.  If it is for campus, than you also may want to look at the 6800 series with VSS.
