Need to change netmask (not IP) on CISCO 9363T
benita.ulisano
Hello, I need to update the netmask on this switch. The switch is currently in production. Does changing the netmask result in a switch reboot?
Thanks in advance,
Benita
Reza Sharifi
No, changing the IP does not result in a reboot but I recommend doing it in a maintenance window as it will cause a short outage.
Reza Sharifi
benita.ulisano
Thank you so much!
Glad to help. Good luck!
