Need to change stack module of 2960
I got a new switch with no stack module inside it at the back. I have a old switch with a stack module. Is it feasible to take out stack module from old 2960 switch and insert it into new 2960 switch as I need to implement new switch in my environment.
My mobile : +91 8860082493
Email: rakesh.phogat@softwareone.com
Rakesh
Need to know the precise 2960 models, for old and new to see if stack modules compatible
Hello
Like for like models - yes it is feasible to do, in fact I have done this a few times recently!
res
Paul
Kind Regards
Paul
Tausif Gaddi
The following are restrictions for your switch stack configuration:
  • Stacking is not supported on switches running the LAN Lite image. All switches in the stack must be running the LAN Base image.
  • In a mixed stack of Catalyst 2960-X and Catalyst 2960-S switches, the number of supported stack members is reduced from eight to four.
  • In a mixed stack of Catalyst 2960-X and Catalyst 2960-S switches, full stack bandwidth is reduced from 80 Gbps to 40 Gbps.
  • In a mixed stack of Catalyst 2960-X and Catalyst 2960-S switches, stack convergence time is increased from milliseconds to 1 to 2 seconds.
Please refer
http://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst2960x/software/15-0_2_EX/stack_manager/configuration_guide/b_stck_152ex_2960-x_cg/b_stck_152ex_2960-x_cg_chapter_010.html
