Need to hid general VLAN from management VLANs.
MatthewN37
Hi I’m not too experienced with ACL’s so I come here seeking your help.
Recently we had a security audit performed and one of the items that was highlighted was that the production VLAN can see the management VLANs (ie SAN, VM host, Security Cameras). So I need to block this access with a ACL for the majority of our users but still need to exclude some members of our department.
So after doing some research I have come up with this.
interface vlan 1
ip address 10.113.0.1 255.255.0.0
ip access-group BAN_VLAN_2 in
interface vlan 2
ip address 10.111.0.1 255.255.0.0
interface vlan 3
ip address 10.114.0.1 255.255.0.0
ip access-list extended BAN_VLAN_2
deny ip 10.111.0.0 0.0.255.255 any
permit ip any any
VLAN 2 being my general VLAN.
Is there a better way of doing this? If so how?
Thanks!
Matthew
nkarthikeyan
Level 7
Level 7
Hi Matthew,
You can restrict that with the ACL as you did . That ACL works like any requests coming from VLAN2 (10.111.0.1) to other VLAN's 1 & 3 will get totally blocked. Make sure that you don need anyother specific communications required from vlan 2 to the other vlans 1 & 3.
Please do rate if the given information helps.
By
Karthik
