Need to shift dhcp scope from l3 switch to dhcp 2012 r2 server
yogesh1
Dear ALL,
I have multiple dhcp scope on l3 switch same need to be shift on dhcp window 2012 server R2 please let us know configuration changes need to be done for this.
9 Replies 9
Deepak Kumar
There is no specific configuration required but some steps have to check or run command.
1. Are you going to install DHCP server on the same VLAN? If not, then run a command "IP helpder-address x.x.x. <DHCP server IP address> under the all VLAN configuration on your core switch.
2. After complete configuration and testing of your server remove the DHCP pool from the switch.
3. Verify that your all systems are getting proper IP configuration from DHCP including IP, Gateway, DNS, or other option as any specifically required option as 82,43, etc. That all are not required in normal desktop or servers.
Deepak Kumar
Deepak Kumar
Deepak Kumar,
Don't forget to vote and accept the solution if this comment will help you!
Dear Deepak,
We have core switch which is connected to router & router which is connected to mpls in this network we have running dhcp server so please specify we have to configure ip helper address on router where we have already advertise ip subnets or we have to configure the dhcp ip helper address on each and every vlan.
Also specify command how to configure ip helper address on switch.??
how the dora process will process from system to router then to dhcp server.
Where is VLAN routing configured? Is it on the core switch or router?
If your VLAN routing is configured on core switch then the command "IP helpder-address X.X.X.X" required on the switch under the each VLANs, which are supplying IP address from your DHCP server.
If VLAN routing is configured on the router then IP helpder-address X.X.X.X" required on the router under the each VLANs.
more specification, can you share your Core switch configuration.
Dora process:
The system will send a broadcast message, in particular, VLAN and VLAN IP helper convert it into  unicast and forward to DHCP server.
Deepak Kumar
Deepak Kumar,
Dear Deepak,
Please find the confg of PI-CORE & Router  I have hide the ip of dns server rest of the config is same.
Please suggest where changes is required to make communication with dhcp server and share the templet
PI-CORE
PI-Core>en
Password:
PI-Core#sh run
PI-Core#sh running-config
Building configuration...
Current configuration : 12435 bytes
! Last configuration change at 12:23:07 IST Fri Feb 2 2018 by
version 15.2
no service pad
service password-encryption
service compress-config
hostname PI-Core
boot-start-marker
boot-end-marker
vrf definition Mgmt-vrf
 address-family ipv4
 exit-address-family
 address-family ipv6
 exit-address-family
no logging console
enable secret 5 $1$4ENJ$Pt9HR7odQMHrCo58UK28W1
username panasonicindia privilege 15 secret 5 $1$VHPe$iCepdr5VRLEYmidkUU6ta1
aaa new-model
aaa session-id common
clock timezone IST 5 30
switch 1 provision ws-c3850-12xs
switch 2 provision ws-c3850-12xs
coap http enable
ip routing
ip domain-name PANASONIC.COM
no ip dhcp conflict logging
ip dhcp excluded-address 10.85.45.1 10.85.45.5
ip dhcp excluded-address 10.85.67.1 10.85.67.5
ip dhcp excluded-address 10.85.64.100 10.85.64.104
ip dhcp excluded-address 10.85.64.1 10.85.64.60
ip dhcp excluded-address 10.85.42.1 10.85.42.20
ip dhcp excluded-address 10.85.41.1 10.85.41.50
ip dhcp excluded-address 137.40.35.1 137.40.35.70
ip dhcp excluded-address 10.85.41.213 10.85.41.225
ip dhcp excluded-address 10.85.67.105
ip dhcp excluded-address 10.85.67.200 10.85.67.205
ip dhcp excluded-address 10.85.40.1 10.85.40.80
ip dhcp excluded-address 10.85.67.226
ip dhcp excluded-address 10.85.64.218
ip dhcp excluded-address 137.40.35.161 137.40.35.162
ip dhcp excluded-address 10.85.40.106
ip dhcp excluded-address 10.85.41.108
ip dhcp excluded-address 137.40.35.102
ip dhcp excluded-address 10.85.41.62
ip dhcp excluded-address 10.85.67.6 10.85.67.7
ip dhcp excluded-address 10.85.67.16
ip dhcp excluded-address 10.85.65.117
ip dhcp excluded-address 10.85.65.251
ip dhcp excluded-address 10.85.89.1 10.85.89.50
ip dhcp excluded-address 10.85.64.237
ip dhcp excluded-address 137.40.35.180
no ip dhcp ping packets
ip dhcp pool LAN
 network 10.85.67.0 255.255.255.0
 default-router 10.85.67.2
dns-server 10.85.28.33 137.40.35.12 10.81.248.31
netbios-name-server 137.40.35.12 10.85.28.33
 lease 0 8
ip dhcp pool 10.85.42.X
 network 10.85.42.0 255.255.255.0
 default-router 10.85.42.2
 lease 0 8
ip dhcp pool 10.85.41.X
 network 10.85.41.0 255.255.255.0
 default-router 10.85.41.1
 lease 0 8
ip dhcp pool 137.40.35.X
 network 137.40.35.0 255.255.255.0
 default-router 137.40.35.1
 lease 0 8
ip dhcp pool 11thfloor
 network 10.85.40.0 255.255.255.0
 default-router 10.85.40.1
 lease 0 8
ip dhcp pool WIRELESS
 network 10.85.64.0 255.255.254.0
 default-router 10.85.64.2
 lease 0 8
ip dhcp pool Mobility
 network 10.85.89.0 255.255.255.0
 default-router 10.85.89.1
 lease 0 8
qos queue-softmax-multiplier 100
crypto pki trustpoint TP-self-signed-2007993793
 enrollment selfsigned
 subject-name cn=IOS-Self-Signed-Certificate-2007993793
 revocation-check none
 rsakeypair TP-self-signed-2007993793
crypto pki certificate chain TP-self-signed-20079
 certificate self-signed 01
  3082022B 30820194 A0030201 02020101 300D0609 2A864886 F70D0101 05050030
  31312F30 2D060355 04031326 494F532D 53656C66 2D536967 6E65642D 43657274
  69666963 6174652D 32303037 39393337 3933301E 170D3137 30363037 31303337
  34325A17 0D323030 31303130 30303030 305A3031 312F302D 06035504 03132649
DC557EDD 5434F520 53BECA95
  D6FB9EA5 CD39C3A3 2995DC26 1F4F5F
        quit
diagnostic bootup level minimal
spanning-tree mode pvst
spanning-tree vlan 1-4094 priority 24576
hw-switch switch 1 logging onboard message level 3
hw-switch switch 2 logging onboard message level 3
redundancy
 mode sso
class-map match-any non-client-nrt-class
policy-map port_child_policy
 class non-client-nrt-class
  bandwidth remaining ratio 10
interface Port-channel9
 switchport mode trunk
interface GigabitEthernet0/0
 vrf forwarding Mgmt-vrf
 no ip address
 negotiation auto
interface TenGigabitEthernet1/0/1
 description "Connected With 12_Floor_HUB1"
interface TenGigabitEthernet1/0/2
 description "Connected With 12_Floor_HUB3"
interface TenGigabitEthernet1/0/3
 description "Connected With 12_Floor_HUB4"
interface TenGigabitEthernet1/0/4
 description "Connected With 12_Floor_HUB6"
interface TenGigabitEthernet1/0/5
 description "Connected With 11_Floor_HUB1"
interface TenGigabitEthernet1/0/6
 description "Connected With 11_Floor_HUB2"
interface TenGigabitEthernet1/0/7
 description "Connected With 11_Floor_HUB3"
interface TenGigabitEthernet1/0/8
 description ""Connected with HUB-9 11th floor""
interface TenGigabitEthernet1/0/9
 channel-group 9 mode on
interface TenGigabitEthernet1/0/10
interface TenGigabitEthernet1/0/11
 description ""uplink Cisco WLC_2504""
interface TenGigabitEthernet1/0/12
 description "Connected with MPLS(Primary)RTR-1"
 switchport access vlan 80
 switchport mode access
 speed 100
 duplex full
 spanning-tree portfast
interface TenGigabitEthernet1/1/1
interface TenGigabitEthernet1/1/2
interface TenGigabitEthernet1/1/3
interface TenGigabitEthernet1/1/4
interface TenGigabitEthernet2/0/1
 spanning-tree vlan 10 cost 200
interface TenGigabitEthernet2/0/2
interface TenGigabitEthernet2/0/3
interface TenGigabitEthernet2/0/4
interface TenGigabitEthernet2/0/5
interface TenGigabitEthernet2/0/6
interface TenGigabitEthernet2/0/7
interface TenGigabitEthernet2/0/8
 description "" Connected with HUB-9 11th Floor""
interface TenGigabitEthernet2/0/9
interface TenGigabitEthernet2/0/10
interface TenGigabitEthernet2/0/11
 switchport access vlan 70
 speed 100
interface TenGigabitEthernet2/0/12
 description "Connected with MPLS(Secondary)RTR-2"
 speed 100
 duplex full
interface TenGigabitEthernet2/1/1
interface TenGigabitEthernet2/1/2
interface TenGigabitEthernet2/1/3
interface TenGigabitEthernet2/1/4
interface Vlan1
 ip address 10.85.64.2 255.255.254.0
interface Vlan10
 ip address 10.85.45.2 255.255.255.0
interface Vlan11
 ip address 10.85.40.1 255.255.255.0
interface Vlan20
 ip address 10.85.67.2 255.255.255.0
interface Vlan30
 ip address 10.85.41.1 255.255.255.0
interface Vlan40
 ip address 10.85.42.2 255.255.255.0
interface Vlan50
 ip address 137.40.35.1 255.255.255.0
interface Vlan70
 no ip address
 ip helper-address 192.168.1.1
interface Vlan80
 ip address 10.85.80.5 255.255.255.0
interface Vlan89
 ip address 10.85.89.1 255.255.255.0
ip forward-protocol nd
ip http server
ip http authentication local
ip http secure-server
ip route 0.0.0.0 0.0.0.0 10.85.80.1
ip sla enable reaction-alerts
logging trap debugging
logging host 137.40.35.161
snmp-server community pana123 RO
snmp-server enable traps snmp authentication linkdown linkup coldstart warmstart
snmp-server enable traps transceiver all
snmp-server enable traps cpu threshold
snmp-server enable traps tty
snmp-server enable traps eigrp
snmp-server enable traps ospf state-change
snmp-server enable traps ospf errors
snmp-server enable traps ospf retransmit
snmp-server enable traps ospf lsa
snmp-server enable traps ospf cisco-specific state-change nssa-trans-change
snmp-server enable traps ospf cisco-specific state-change shamlink interface-old
snmp-server enable traps ospf cisco-specific state-change shamlink neighbor
snmp-server enable traps ospf cisco-specific errors
snmp-server enable traps ospf cisco-specific retransmit
snmp-server enable traps ospf cisco-specific lsa
snmp-server enable traps auth-framework sec-violation
snmp-server enable traps flash insertion removal
snmp-server enable traps power-ethernet police
snmp-server enable traps energywise
snmp-server enable traps vtp
snmp-server enable traps vlancreate
snmp-server enable traps vlandelete
snmp-server enable traps license
snmp-server enable traps envmon fan shutdown supply temperature status
snmp-server enable traps stackwise
snmp-server enable traps port-security
snmp-server enable traps fru-ctrl
snmp-server enable traps entity
snmp-server enable traps cef resource-failure peer-state-change peer-fib-state-change inconsistency
snmp-server enable traps config-copy
snmp-server enable traps config-ctid
snmp-server enable traps event-manager
snmp-server enable traps hsrp
snmp-server enable traps ipmulticast
snmp-server enable traps pim neighbor-change rp-mapping-change invalid-pim-message
snmp-server enable traps vstack
snmp-server enable traps bridge newroot topologychange
snmp-server enable traps stpx inconsistency root-inconsistency loop-inconsistency
snmp-server enable traps syslog
snmp-server enable traps ipsla
snmp-server enable traps errdisable
snmp-server enable traps mac-notification change move threshold
snmp-server enable traps vlan-membership
snmp-server host 137.40.35.102 version 2c ro
snmp-server host 137.40.35.102 version 2c wr
banner login ^CXTCCC
WARNING: This system is for the use of authorized ADMINISTRATOR only.
Individuals trying to connect to the network devices without authorization are
subject to having all their reactivity on this network domain monitored and
recorded by log server.
Anyone connected to the terminal expressly consents to such monitoring and is
advised that if such monitoring reveals possible conduct of criminal activity,
network monitoring tools may provide the evidence of such activity to the
Network Administrator.
Unauthorized access is a violation of law and may lead to criminal action.
^C
banner motd ^CXTCCC
                    WARNING:                              $$$$
^C
line con 0
 stopbits 1
line aux 0
line vty 0 4
 transport input ssh
line vty 5 15
 transport input ssh
wsma agent exec
 profile httplistener
 profile httpslistener
wsma agent config
wsma agent filesys
wsma agent notify
wsma profile listener httplistener
 transport http
wsma profile listener httpslistener
 transport https
ap group default-group
end
PI-Core#
PI-Core#
PI-Core>en
Password:
PI-Core#sh run
version 15.2
no service pad
hostname PI-Core
boot-start-marker
boot-end-marker
 address-family ipv4
 exit-address-family
 address-family ipv6
 exit-address-family
no logging console
aaa new-model
coap http enable
ip routing
ip dhcp pool LAN
 lease 0 8
 lease 0 8
 lease 0 8
 lease 0 8
 lease 0 8
 lease 0 8
 lease 0 8
        quit
redundancy
 mode sso
 no ip address
 negotiation auto
 speed 100
 duplex full
 speed 100
 speed 100
 duplex full
interface Vlan1
interface Vlan10
interface Vlan11
interface Vlan20
interface Vlan30
interface Vlan40
interface Vlan50
interface Vlan70
 no ip address
interface Vlan80
interface Vlan89
ip http server
^C
banner motd ^CXTCCC
                    WARNING:                              $$$$
^C
line con 0
 stopbits 1
line aux 0
line vty 0 4
 transport input ssh
line vty 5 15
 transport input ssh
wsma agent exec
wsma agent config
wsma agent filesys
wsma agent notify
 transport http
 transport https
end
PI-Core#
PI-Core#
Please find the router config below
Panasonic_India_Gurgaon>en
Password:
Panasonic_India_Gurgaon#
Panasonic_India_Gurgaon#sh run
Panasonic_India_Gurgaon#sh running-config
Current configuration : 8261 bytes
! Last configuration change at 10:26:55 IST Fri Jun 23 2017 by
version 15.4
service timestamps debug datetime msec localtime
service timestamps log datetime msec localtime
hostname
boot-start-marker
boot-end-marker
logging buffered 4098
enable secret 5 $1$7n5Q$vrpXfZojEXYUggNIO2PZY1
aaa new-model
aaa authentication login default group tacacs+ local
aaa authentication enable default group tacacs+ enable
aaa authorization console
aaa authorization config-commands
aaa authorization exec default group tacacs+ local
aaa authorization commands 1 default group tacacs+ local
aaa authorization commands 15 default group tacacs+ local
aaa accounting exec default start-stop group tacacs+
aaa accounting commands 1 default start-stop group tacacs+
aaa accounting commands 15 default start-stop group tacacs+
aaa accounting connection default start-stop group tacacs+
no ip source-route
ip dhcp excluded-address 10.10.10.1
ip dhcp pool ccp-pool
 import all
 network 10.10.10.0 255.255.255.128
 default-router 10.10.10.1
 lease 0 2
no ip bootp server
ip domain name yourdomain.com
ip cef
no ipv6 cef
cts logging verbose
crypto pki trustpoint TP-self-signed-2607201271
 subject-name cn=IOS-Self-Signed-Certificate-2607201271
 rsakeypair TP-self-signed-2607201271
crypto pki certificate chain TP-self-signed-26
  69666963 6174652D 32363037 32303132 3731301E 170D3135 30383236 30343039
  33365A17 0D323030 31303130 30303030 305A3031 312F302D 06035504 03132649
  4F532D53 656C662D 5369676E 65642D43 65727469 66696361 74652D32 36303732
  30313237 3130819F 300D0609 2A864886 F70D0101 01050003 818D0030 81890281
  8100C91F DB7EFC4D F8933480 79CBEBC0 8B81306E E85A46BF 6615C72D 54D0B762
  7CA5ED3C FD45602E 856F4957 2223C821 D112A04F 2711AC6E 020086EB 722E9FA2
  2E45FA83 77D2028E FE1773FF 94D9FF19 B3492573 C4FB4F5C C1DEB46E CEE0D726
  BF4D1937
        quit
license udi pid CISCO1941/K9 sn FGL193520WY
username vsnl password 7 021605552B101C2F40
username emergency privilege 15 secret 5 $1$Pps2$3m1V5jR5kACIhoHPpGuOK/
redundancy
track 1 ip sla 1 reachability
track 2 ip sla 2 reachability
interface Loopback0
 description *** Management Loopback ***
 ip address 10.85.169.207 255.255.255.255
interface Loopback12312312
 no ip address
interface Embedded-Service-Engine0/0
 no ip address
 shutdown
 description *** LAN LINK ***
 ip address 10.85.80.2 255.255.255.0
 ip accounting output-packets
 standby 1 ip 10.85.80.1
 standby 1 timers 1 3
 standby 1 priority 130
 standby 1 preempt delay minimum 25
 standby 1 name PRIMARY
 standby 1 track 2 decrement 40
 duplex full
 speed 100
interface GigabitEthernet0/1
 description *** TCL WAN ***
 ip address 10.85.148.226 255.255.255.252
 load-interval 30
 duplex full
 speed 100
router bgp 64916
 bgp log-neighbor-changes
 neighbor 10.85.148.225 remote-as 4755
 address-family ipv4
  network 10.85.40.0 mask 255.255.255.0
  network 10.85.41.0 mask 255.255.255.0
  network 10.85.42.0 mask 255.255.255.0
  network 10.85.45.0 mask 255.255.255.0
  network 10.85.64.0 mask 255.255.255.0
  network 10.85.65.0 mask 255.255.255.0
  network 10.85.67.0 mask 255.255.255.0
  network 137.40.35.0 mask 255.255.255.0
  redistribute connected
  redistribute static
  neighbor 10.85.138.225 activate
  neighbor 10.85.138.225 soft-reconfiguration inbound
 exit-address-family
no ip http server
ip http access-class 23
ip http timeout-policy idle 60 life 86400 requests 10000
ip route 10.85.40.0 255.255.255.0 GigabitEthernet0/0 10.85.80.5
ip route 10.85.41.0 255.255.255.0 GigabitEthernet0/0 10.85.80.5
ip route 10.85.42.0 255.255.255.0 GigabitEthernet0/0 10.85.80.5
ip route 10.85.45.0 255.255.255.0 GigabitEthernet0/0 10.85.80.5
ip route 10.85.64.0 255.255.255.0 GigabitEthernet0/0 10.85.80.5
ip route 10.85.65.0 255.255.255.0 GigabitEthernet0/0 10.85.80.5
ip route 10.85.67.0 255.255.255.0 GigabitEthernet0/0 10.85.80.5
ip route 10.85.89.0 255.255.255.0 GigabitEthernet0/0 10.85.80.5
ip route 137.40.35.0 255.255.255.0 GigabitEthernet0/0 10.85.80.5
ip access-list standard TATA-MONITORING-SNMP
 permit 121.244.180.47
 permit 121.244.180.37
 permit 121.244.227.114
 permit 121.244.180.36
 permit 121.244.227.113
 permit 115.114.226.164
 permit 115.114.9.67
 permit 115.114.9.68
 permit 10.70.0.202
 permit 10.70.0.199
 permit 202.54.29.81
 permit 115.114.146.71
 permit 115.114.146.70
 permit 115.114.146.69
 permit 115.114.226.160 0.0.0.31
 permit 115.114.219.32 0.0.0.15
 deny   any
ip access-list standard TCL_SNMP
 permit 115.114.9.67
 permit 115.114.9.68
 permit 10.70.0.201
 permit 10.70.0.202
 permit 10.70.0.199
 permit 202.54.29.81
 permit 172.31.6.123
 permit 202.54.29.25
 permit 115.114.219.35
 permit 202.54.29.27
 permit 10.209.19.0 0.0.0.255
 deny   any
ip sla 1
 icmp-echo 10.75.246.73 source-interface GigabitEthernet0/1
ip sla schedule 1 life forever start-time now
ip sla 2
 icmp-echo 10.85.138.225 source-interface GigabitEthernet0/1
ip sla schedule 2 life forever start-time now
ip sla responder
logging facility local5
logging source-interface GigabitEthernet0/1
logging host 10.70.0.201
logging host 10.209.19.200
logging host 121.244.180.36
logging host 121.244.180.37
logging host 121.240.118.90
logging host 115.114.170.78
logging host 115.114.151.107
logging host 115.114.151.114
snmp-server community t2c2l2com RO TCL_SNMP
snmp-server community pan@vsnl RO 10
snmp-server ifindex persist
snmp mib persist cbqos
tacacs-server host 10.70.0.201
tacacs-server directed-request
tacacs-server key 7 051D15012D
access-list 10 permit 203.200.231.222
access-list 10 permit 10.70.0.202
access-list 10 permit 172.31.6.123
access-list 10 permit 202.54.29.25
access-list 10 permit 10.209.19.0 0.0.0.255
access-list 10 deny   any
access-list 23 permit 10.10.2.0 0.0.0.127
control-plane
privilege exec level 4 traceroute ip
privilege exec level 4 ping ip
privilege exec level 4 show ip accounting
privilege exec level 4 show ip interface brief
privilege exec level 15 show startup-config
privilege exec level 4 show configuration
privilege exec level 4 show interfaces description
privilege exec level 4 clear ip accounting
privilege exec level 4 clear counters
line con 0
line aux 0
line 2
 no activation-character
 no exec
 transport preferred none
 transport output pad telnet rlogin lapb-ta mop udptn v120 ssh
 stopbits 1
line vty 0 4
 password 7 05080F1C2243
 transport input telnet ssh
line vty 5 15
 access-class 23 in
 privilege level 15
scheduler allocate 20000 1000
ntp source GigabitEthernet0/1
ntp update-calendar
ntp server 10.75.26.73
end
Please configure IP helper command on your Core switches. for example as below:
Suppose your DHCP IP address:  192.168.1.100 and it is in VLAN 10 so reset VLAN configuration must me like:
interface Vlan30
 ip helper-address 192.168.1.100
interface Vlan40
interface Vlan50
interface Vlan80
etc.
Deepak Kumar
Deepak Kumar,
Dear Deepak,
Is there requirement of enabling of IP DHCP relay also if we already enable ip helper address on particular vlan
Dear Deepak,
Is there requirement of enabling of IP DHCP relay command on l3 switch  also if we already enable ip helper address on each vlan.
No need for IP DHCP Relay command.
Deepak Kumar
Deepak Kumar,
basically, the ip helper-address command goes on the first Layer 3 interface that is between your clients and the DHCP server. In the example below, the 'ip helper-address' command needs to be configured on the Vlan10 interface. What this command does: it converts the DHCP broadcast sent out by the clients into a routable unicast, allowing the DHCP request to be routed to your DHCP server...
PC --> Vlan10 (SVI) --> DHCP server
