need to update firmware c9300 48
Biju KIV
hi
I tried to upgrade via USB. the new firmware cat9k_iosxe.17.09.05.SPA.bin
the command i used is
switch# copy usbflash0:cat9k_iosxe.17.09.05.SPA.bin
switch# source file: cat9k_iosxe.17.09.05.SPA.bin
switch #destination file: i gave the existing file of the switch.
It didnt upgrade. screenshot for your reference
May I know the exact cli commands. I tried thru web browser. I am not able to login with default password ,.user webui. password cisco
I havent created any username password thru CLI commands
7 Replies 7
@Biju KIV
 Can you share the command "show version" ? The whole output please
Leo Laohoo
Please read the attachment and perform the upgrade in Install Mode.
Couldn't able to switch on the switch. It's stuck
Please see attached
Biju
If the switch is in ROMMON, post the entire output to the command "set".
Hi the switch is not loading
Please see attached
Biju KIV
hi. its keep on showing this
                    >...hi. its keep on showing this
   - Make sure current ROMMON version is compatible , check : https://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst9300/software/release/17-9/release_notes/ol-17-9-9300/rommon_versions.html
                              Also have a look athttps://bst.cloudapps.cisco.com/bugsearch/bug/CSCvj29562
  M.
