Need to use an IP from an ISP provided /29 on another device for egres
squarenupe33
i have a cisco 4431 connected to my ISP.  the ISP provided a single /29.  I need to use an IP of the /29 on the WAN port of another device for Internet egress out that device.  how can i share (VLAN) the /29 since the 4431 is receiving the /29 on a routed port?  the rough diagram illustrates:
7 Replies 7
Jens Albrecht
Hello @squarenupe33,
create a static NAT entry on your 4431 to translate the internal address of this device to one of your /29 WAN addresses (.3 in your diagram).
Of course, limit the reachability from the internet to only those ports that really need to be exposed.
HTH!
M02@rt37
Hello @squarenupe33
You can share the /29 subnet by configuring a software bridge on the 4431. This bridges the ISP-facing interface and the SASE-facing interface at L2, allowing both the router and the SASE edge to use IPs from the same /29. The 4431 uses a BVI for its IP, and the SASE edge can use another IP from the subnet.
See here: https://travelingpacket.com/2018/03/06/cisco-isr-4000-bridge-group-with-vlans/
Best regards
i was able to implement the following config on the router:
interface GigabitEthernet0/0/1
no ip address
media-type sfp
negotiation auto
service instance 33 ethernet
  encapsulation untagged
  bridge-domain 33
interface BDI33
ip address 146.x.x.2 255.255.255.248
this config did bridge the routed port.  i can ping, using the bdi33 as the source, the g/w of .1 and external IP 8.8.8.8.  However the 4431 has a 8 port switch module and that is where i wanted to connect the SASE edge device using VLAN tagging.  i was hoping to tag the ISP packets ingress with a VLAN tag so i can use that VLAN on a switch port to share the ISP's /29.  do you know if that is possible.  otherwise, i would have to use 2 routed ports on the 4431 and put them in the bridge group as g0/0/1 which would be a waste of the routed ports.
the 4431 router has the following interfaces:
RTR01-STF#sh ip int brie
Interface I                                  P-Address        OK? Method Status Protocol
GigabitEthernet0/0/0                66.x.x.21           YES NVRAM up up
GigabitEthernet0/0/1                unassigned        YES manual up up
GigabitEthernet0/0/2                unassigned        YES NVRAM down down
GigabitEthernet0/0/3                unassigned        YES NVRAM down down
GigabitEthernet0/2/0                unassigned        YES unset up up
GigabitEthernet0/2/1                unassigned        YES unset down down
GigabitEthernet0/2/2                unassigned        YES unset up up
GigabitEthernet0/2/3                unassigned        YES unset up up
GigabitEthernet0/2/4                unassigned        YES unset down down
GigabitEthernet0/2/5                unassigned        YES unset up up
GigabitEthernet0/2/6                unassigned        YES unset down down
GigabitEthernet0/2/7                unassigned        YES unset down down
GigabitEthernet0                      10.x.x.4              YES NVRAM up up
BDI33                                      16.x.x.2              YES manual up up
Vlan1                                       71.x.x.8              YES NVRAM up up
Vlan33                                     unassigned         YES unset up up
i have a laptop connected to witch port g0/2/5 on the router with an IP address .3 in the ISP's /29.  i cannot ping the ISP .1 or the .2 on the router interface BDI33 from the laptop.
updated image information
Hello @squarenupe33
You want to extend that bridged domain over to the switch module ?
Best regards
yes, i want to extend the bridge domain over to the switch module in the same router.  that way i can use the switch ports for L2 to get to the ISP /29 as opposed to using routed ports converted to L2.  i have 2 SASE devices in an HA config so i need 2 IP addresses from the ISP /29 which means i would have to convert the remaining 2 routed ports to L2.
