Neflow exporter error on 3850
We've setup netflow version 9 on our 3850 running IOS 03.07.04E
flow exporter AWSSplunk
 description test
 destination x.x.13.245
 transport udp 9996
 option interface-table timeout 60
 option application-table timeout 60
flow monitor MONITOR1
 exporter AWSSplunk
 cache timeout inactive 30
 cache timeout active 60
 record RECORD1
flow record RECORD1
 match datalink mac source address input
 match ipv4 protocol
 match ipv4 source address
 match ipv4 destination address
 match transport source-port
 match transport destination-port
We applied the monitor to Vlan 10:
vlan configuration 10
ip flow monitor MONITOR1 input
Exporter is not sending.
When we debug:
debug flow exporter AWSSplunk error
we see this error:
Jan 19 14:36:52: FLOW EXP: Failed to send pak (0x39767FA8) for exporter AWSSplunk : (Unspecified failure)
What could be the problem?
7 Replies 7
Mark Malone
is it even collecting flows in the router itself , you may be hitting a bug did you check your release notes to see if there were any open caveats for that version , im running 3.6.2 bit earlier netfow works fine on it
you can ping the destination fine yes and no FW between switch and collector correct port set on collector side
did you try set a source interface under the exporter too
xxxxx#sh flow exporter statistics
Flow Exporter xxxxxxxxxxxxxxxxxxx:
  Packet send statistics (last cleared 30w4d ago):
    Successfully sent:         30579421              (28363184521 bytes)
    Reason not given:          36698                 (24004144 bytes)
There are no open caveats for my version.
I can ping the collector, no FW in between
Source: this switch has only one ip address (SVI)
#show flow exporter statistics
Flow Exporter AWSSplunk:
  Packet send statistics (last cleared 3d21h ago):
    Successfully sent:         98832                 (104151210 bytes)
    No FIB:                    471962                (645808896 bytes)
  Client send statistics:
    Client: Flow Monitor MONITOR1
      Records added:           1457215
        - sent:                1457215
      Bytes added:             27687085
        - sent:                27687085
    Client: Option options application-name
      Records added:           6213508
        - failed to send:      6213508
      Bytes added:             515721164
        - failed to send:      515721164
    Client: Option options interface-table
      Records added:           657189
        - failed to send:      657189
      Bytes added:             65718900
        - failed to send:      65718900
Looks like it sent some flows nearly 100000 in 3 days but sopme have failed too which is expected   , did you try change the transport port to 2055 ? or make sure the collector is definitely set correctly , you could span the port see if there definitely leaving the switch
I spanned the port and there is no udp traffic coming from the switch
I tried changing the port before, same thing.
open a TAC or try change the software see if it fixes it
I must be doing something wrong
I installed version 3.6.2 and I am getting the same error.
Can you show me your config please?
heres a full working config off my VSS
flow record FLOW-RECORD
 description record to monitor network traffic
 match ipv4 tos
 match ipv4 protocol
 match interface input
 match interface output
 collect routing source as
 collect routing destination as
 collect routing next-hop address ipv4
 collect transport tcp flags
 collect counter bytes
 collect counter packets
 collect timestamp sys-uptime first
 collect timestamp sys-uptime last
flow exporter NetQos
 description export Netflow traffic to HQ
 destination x.x.x.x
 source xxxxx
 template data timeout 300
 option interface-table timeout 1000
 option exporter-stats timeout 1000
flow monitor xilinx_nq
 description Used for ipv4 traffic analysis (Mapped To FLOW-RECORD)
 record FLOW-RECORD
 exporter NetQos
 statistics packet protocol
interface Vlan159
 ip address x.x.x.x 255.255.255.0
 ip flow monitor xilinx_nq input
 ip flow monitor xilinx_nq output
 load-interval 30
end
