Named and numbered ACL
jonk34567
Level 4
Level 4
i have attached my topology diagram below.in that i want to permit traffic from R2 (10.1.1.1/24 )  to R4 ( 20.1.1.2).i want to block all rest  of the traffic . so i entered below command on R1
# access-list  100  permit  ip  host  10.1.1.1  host  20.1.1.2
#int fa 0/0
# ip access-group 100 in
#end
but it doesnt work . i can not ping from R2 to  R4
Hello
Do you have any dynamic routing active, if so you need to allow that through
Example:( depends on what IGP you are using)
access-list 100 permit ospf any any
access-list 100 permit udp any any eq rip
access-list 100 permit eigrp any any
access-list 100 permit ip host 10.1.1.1 any
R4
int fa0/0
no ip unreachables
res
Paul
Kind Regards
Paul
Do you have any routing protocol running or even static routes?
Were you able to successfully ping the interface before you applied the ACL?
If the answer for above is yes then try to source the ping with the 10.1.1.1 IP address.
Cheers,
Mark Malone
Hi you can ping fine between 10.1.1.1 to 20.1.1.2 before you apply the acl yes ?
yes i can ping
Hello
R4
int fa0/0
no ip unreachables
res
Paul
Kind Regards
Paul
