neighbor allowas-in
Hi All,
I would like to know about the usage of the command "neighbor allowas-in". We using the command on CE for the neighbour to PE.
What does this command do the prefixes learned from PE?
What is the reason to use this command ?
Thiyagu
Reza Sharifi
fb_webuser
Level 6
Level 6
This is done if the AS numbers are duplicated, to allow the readvertisement of all prefixes that contain duplicate ASNs
Posted by WebUser Neeraj Jagga from Cisco Support Community App
By default, BGP will drop a route if it sees it's own AS in the advertisement. Allowas-in allows this to happen. You'll see this mainly when MPLS LSP is between you and another site you own. If you want to run BGP between the 2 locations, your location will not allow the traffic inbound. Some providers will override your AS and put theirs in its place so you will get the update. If you know for a fact that you won't get a routing loop, you can use the "allowas-in" with no worries, but it pretty much disables BGP's protection that I stated above.
HTH,
John
HTH, John *** Please rate all useful posts ***
