Nested Class-maps
Valgavv
Community Member
I'm trying to configure a QoS policy using modular QoS configuration, specifically nested class-maps.  I'm configuring a Cisco 3850 using IOS XE Denali 16.6.2.  After defining a couple of single class-maps, I tried to group them using the command 'match class-map'.  The switch errors out as if that command doesn't exist. When I hit the '?' after the match, class-map doesn't even show up as a usual command.  What am I doing wrong?  Ex configuration below:
class-map match-any test1
match access-group test_acl1
class-map match-any test2
match access-group test_acl2
class-map match-any combined_test_class
match class-map test1
match class-map test2
0 Replies 0
