netbios
carl_townshend
Hi all, can anyone give me a quick explanation what this is, and do we still use it today ?
Sureshdank
Level 4
Level 4
Carl,
You can just go though this link and you will get a clear picture of NetBIOS.
http://en.wikipedia.org/wiki/NetBIOS
Pls. Rate the post if it help.
Suresh Jain
Hi, Thanks for the reply but the link is not working !!
thanks
Carl
NetBIOS is an acronym for Network Basic Input/Output System. The NetBIOS API allows applications on separate computers to communicate over a local area network. It provides services related to the session layer of the OSI model.
NetBIOS name
Each computer running Microsoft Windows has a NetBIOS name; you can view/change it on the identification tab in Control Panel -> Network. Various services & client tools, including Network Neighborhood and NET USE, use NetBIOS names. The NetBIOS name is specified when Windows networking is installed/configured. In order to connect to a computer running TCP/IP via its NetBIOS name, the name must be resolved to an IP address (the NetBIOS name-IP address resolution is often done by WINS - NetBIOS Name Server). A computer's NetBIOS name is often the same as that computer's host name (see below), but it doesn't have to be.
Host name
A Windows machine's NetBIOS name is not to be confused with the computer's host name. Each computer running TCP/IP (whether it's a Windows machine or not) has a host name (also sometimes called a machine name). You can view/change it on the DNS tab in Control Panel -> Network -> TCP/IP -> Properties Host names are used by applications such as telnet, ftp, web browsers, etc. In order to connect to a computer running the TCP/IP protocol using its HOST name, the host name must be resolved into an IP Address (the host name or FQDN (Fully Qualified Domain Name)-IP address resolution is typically done by something called DNS - Domain Name System/Service). Changing a computer's Host name does not change its NetBIOS name.
