Netconf Configuration problem
JohnJudi
Level 2
Level 2
Hi friends,
I have a C9500-40X switch.
I configured my switch for Netconf with below commands:
netconf-yang
when I try to telnet switch on port 830, it works!
I wanna configure interface via an python script using netconf. but when I run the script it shows the following syslog message in switch:
66495: 066422: Mar 27 08:20:37.484: Switch 1 R0/0: ncsshd_bp: NETCONF/SSH: fatal: mm_answer_sign: Xkey_sign failed: error in libcrypto
The software of my switch is ios-xe 17.3.3
Do you have any idea about this problem?
thank you in advance for reply
It seems to me that the problem is related to authentication. The user you are using to access have enough privilege?
Xkey_sign failed - something with key exchange.
You have another thread with the same problem but reffering to DNAC, right?  Aree you using DNAC or Scritp, or both?
