storm-control
bluesea2010
Level 7
Level 7
I have the below configuration on the switch port. On some ports,the moment I plugged any device it is going to the error state.
some ports working normal. What could be the issue? .Or the PPS value is very low to have in a access port ?
storm-control broadcast level pps 5
storm-control action shutdown
Mark Elsen
 - Check logs  when the port goes down and or determine if port goes down due to storm-control configurations (or not)
 M.
-- ' Listen to the wind, it talks
          Listen to the silence, it speaks
             Listen to your heart, it knows
Ganado Mucho (1809 to 1893 ) Navajo Indian
balaji.bandi
that is low increase and test it.
there is math calculation, may be you can find over internet
BB
Hello
Suggest to set your SC levels to a much higher rate and then monitor for a while to establish a baseline then apply your BUM levels accordingly, Otherwise you could experience issues like this if those SC levels are set to low for what could be deemed "normal" traffic
Example
int x/x
storm-control broadcast level 99.00
storm-control multicast level 99.00
sh storm-control broadcast/multicast ( so to check on the current value the port is reaching
Kind Regards
Paul
