NetFlow configuraion C9500 with VRF
Ramprasad2
Dear Team,
I have Cisco C9500 switch.and i have configured VRF in the switch and netlfow and syslog server.
but server and syslog server side not received any logs and flow. but i am able to ping syslog and sever ip.
i configured below but not getting any logs. and my inffra use udp port is 9995
if you have any document for this please share
10 Replies 10
Jens Albrecht
Hello @Ramprasad2,
looking at the config you posted before there appear to be some commands missing:
! 1.) Make sure that the VRF is included in the flow record
flow record <RECORD_NAME>
 match routing vrf input
! 2.) Set the source interface with VRF
flow exporter <EXPORTER_NAME>
 source <source-interface> vrf <VRF_NAME>
! 3.) Apply monitor to interface in VRF
interface <interface-in-vrf>
 ip flow monitor <MONITOR_NAME> input
The config for int vlan 1 was missing on your previous post so that I included the last point just for sake of completeness to make the netflow config VRF-aware.
HTH!
M02@rt37
Hello @Ramprasad2
Please check if you source that flow with its VRF dedicated.
Best regards
Ramprasad2
i have configured below commands but still issue [ not getting any logs ]
i have check ( ping and traceroute ] working and firewall pass the traffic
flow record NFARecordinput
match ipv4 source address
match ipv4 destination address
match transport source-port
match transport destination-port
match ipv4 protocol
match interface input
match ipv4 tos
match flow direction
collect interface output
collect counter bytes long
collect counter packets long
collect transport tcp flags
collect timestamp absolute first
collect timestamp absolute last
flow record NFARecordoutput
match ipv4 protocol
match interface output
match ipv4 tos
collect interface input
flow exporter NFAExporter
destination 172.16.100.48 vrf CORP
source Vlan1
transport udp 9995
template data timeout 60
option application-table timeout 60
flow monitor NFAMonitorinput
cache timeout active 60
flow monitor NFAMonitoroutput
interface Vlan1
vrf forwarding CORP
ip flow monitor NFAMonitorinput input
ip flow monitor NFAMonitoroutput output
ip address 10.200.15.1 255.255.255.0
no ip route-cache
Current configuration : 218 bytes
interface TwentyFiveGigE1/0/2
description CONT-TO-HYD-GMR-CORE-SW (Ten 2/0/1)
switchport mode trunk
channel-group 1 mode active
HYD-GMR-DIST-SW#show flow interface
Interface Vlan1
FNF: monitor: NFAMonitorinput
direction: Input
traffic(ip): on
FNF: monitor: NFAMonitoroutput
direction: Output
traffic(ip): on
Interface TwentyFiveGigE1/0/1
direction: Input
traffic(ip): on
direction: Output
traffic(ip): on
Interface TwentyFiveGigE1/0/2
direction: Input
traffic(ip): on
direction: Output
traffic(ip): on
Interface TwentyFiveGigE1/0/3
direction: Input
traffic(ip): on
direction: Output
traffic(ip): on
Interface TwentyFiveGigE2/0/1
direction: Input
traffic(ip): on
direction: Output
traffic(ip): on
Interface TwentyFiveGigE2/0/2
direction: Input
traffic(ip): on
direction: Output
traffic(ip): on
Interface TwentyFiveGigE2/0/3
direction: Input
traffic(ip): on
direction: Output
traffic(ip): on
HYD-GMR-DIST-SW#
HYD-GMR-DIST-SW#
HYD-GMR-DIST-SW#
HYD-GMR-DIST-SW#
HYD-GMR-DIST-SW#sh
HYD-GMR-DIST-SW#show run
HYD-GMR-DIST-SW#show running-config in
HYD-GMR-DIST-SW#show running-config interface TwentyFiveGigE1/0/2
Building configuration...
show flow exporter statistics
Flow Exporter NFAExporter:
Packet send statistics (last cleared 00:48:01 ago):
Successfully sent: 120210 (171879344 bytes)
Client send statistics:
Client: Option options application-name
Records added: 72768
- sent: 72768
Bytes added: 6039744
- sent: 6039744
Client: Flow Monitor NFAMonitorinput
Records added: 1216200
- sent: 1216200
Bytes added: 80492002
- sent: 80492002
Client: Flow Monitor NFAMonitoroutput
Records added: 1279425
- sent: 1279425
Bytes added: 84674638
- sent: 84674638
Packet send statistics (last cleared 00:48:05 ago):
Successfully sent: 120758 (172659036 bytes)
Records added: 74284
- sent: 74284
Bytes added: 6165572
- sent: 6165572
Records added: 1220837
- sent: 1220837
Bytes added: 80798764
- sent: 80798764
Records added: 1284456
- sent: 1284456
Bytes added: 85007720
- sent: 85007720
vrf  CORP <<- Add this abd check
MHM
@MHM Cisco World pleas explain in details
source Vlan1
transport udp 9995
For netflow export it need to be vrf ware'
So source use packet must use interface in same of vrf use to reach server
And we need to add
Vrf ""xxxx""
To make netflow use vrf to reach server not global table
MHM
can you share also
show ip flow export
MHM
Ramprasad2
i run the command in flow exporter NFAExporter
vrf CORP but command not run
and my switch ios is 17.12.4
CORE-SW#show ip flow export ?
% Unrecognized command
% Invalid input detected at '^' marker.
CORE-SW#show flow exporter
Description: User defined
Export protocol: NetFlow Version 9
Transport Configuration:
Destination type: IP
Destination IP address: 172.16.100.48
VRF label: CORP
Source IP address: 10.200.15.80
Source Interface: Vlan1
Transport Protocol: UDP
Destination Port: 9995
Source Port: 49772
DSCP: 0x0
TTL: 255
Output Features: Used
Export template data timeout: 60
Options Configuration:
application-table (timeout 60 seconds) (active)
CORE-SW#
debug flow export
debug flow monitor
show ip route vrf CORP
share above please
MHM
