Netflow lite issue
vyas.nilay
Level 3
Level 3
hi,
I am trying to configure the Netflow lite on the 2960x.
Core L3 --- 2960x L2 switch --- Core L3
None of the core is supporting Netflow.
L2 swith is configur with VLAN 30 to enable routing.
I want to catpure the netflow.
Configuration applied:
flow record testrecord
match ipv4 protocol
match ipv4 source address
match ipv4 destionation address
match transport source-port
match transport destination-port
collect transport tcp flags
collect interface input
collect counter byptes long
collect coutner packets long
collect timestamp sys-uptime first
collect timestamp sys-uptime last
flow exporter testexport
destination 192.168.8.110
source vlan 8
output-features
transport udp 9995
flow monitor testmonitor
exporter testexport
record test record
cache timeout inactive 120
cache timeout active 15000
Sampler testsmapler
mode random 1 out-of 32
int gig 1/0/46
ip flow monitor testmonitor sampler testsampler input
when I issue show command
show flow explorter stat
it shows 0 on them
Can someone please guide me where did I go wrong?
no routing is not enable.
However the switch management is address is in vlan 8 - 192.168.8.250
Collector is connected to same switch on port 28 with IP - 192.168.8.110
default gateway of the switch is 192.168.8.1
Nilay
5 Replies 5
Reza Sharifi
What is license level on the switch?
Prerequisites for NetFlow Lite
NetFlow Lite is only supported on a Catalyst 2960-X Switch with a LAN Base license and on a Catalyst 2960-XR Switch with an IP Lite license. Catalyst 2960-XR is not stackable with the Catalyst 2960-X platform.
https://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst2960x/software/15-2_2_e/fnf/configuration_guide/b_fnf_1522e_2960x_cg/b_fnf_32se_3850_cg_chapter_010.html
Hi Reza,
It is
WS-C2960X-48LPS-L with software Version 15.2(2)E5 and active licence is LAN BASE.
Nilay.
It is two switch stack with same model and liceces.
Is ip routing enabled  on the switch?
Is the destination IP reachable from the switch?
Nilay
