Network Admin interview questions
ushakiran
Community Member
Dear Folks,
Today i have attend one interview as Network Administrator, But i mishap that chances because of my poor ignorance.
i dint answers what they asked the questions no one of the below questions can you please share the answers
1. in a organization 1000 systems are connected to  multiple switches as well as routers, in out of 1000 systems one of the machines has down.  so how we find out the route cause in which switch as well as router has down and how to troubleshoot
2.in a organization wan network has implemented through the router as well as switches ok one of the machines has not connected wireless out of 1000, so how we find out the specific machine has down. and how to troubleshoot
3. in one of the PC->connected to switch->connected router->internet ( Q: how the internet is coming to the pc and what is the process.
Julio E. Moisa
Questions 1 and 2 are not so clear but I will try my best, assuming machine = PC.
The user should report the problem first so you should to know what PC is, otherwise if the PC's mac address is still into the mac address table you could use show mac address-table | inc <mac address>, or find a PC down between a network built between 1000 networks devices you could first identify what network segment is using the PC and check the switches configured with the specific VLAN, and check logs, once identified the PC, you should check the physical layer first (cabling, power, hardware) , next troubleshoot the other layers.
Like the previous question, the user should report the problem so you could find the what device has problems, once it is identified you could verify physical layer (NIC o hardware) or drivers, then verify what credentials is using to connect to the WiFi, identify the logs on any closest access point, check the network association on the AP in order to verify if it is not in full capacity.
It looks like the network has a PAT configured on the router, basically the internal IP will be translated to a public IP, if you are using PAT, it will be works with ports, the PC will open a request using a random port, the PAT configured on the router will translate the internal IP to the public IP but it will also map the internal port and a random external port so the destination will know how to return the information to the source.
Hope it is useful
>> Marcar como útil o contestado, si la respuesta resolvió la duda, esto ayuda a futuras consultas de otros miembros de la comunidad. <<
