Network connection fail
iansmith0287
Community Member
Is there any reason why a PuTTY would not ssh remote into some Cisco switches? PuTTY works for every other switch, with the exception of our 9200L Cisco switch. I keep receiving this error: "Network error: connection timed out".
Mark Elsen
 - Either SSH (access)  is not correctly configured on the 9200L (presuming this is the protocol you are trying, or there is an intermediate firewall blocking SSH access , you may for instance try to ping it. (For  telnet same arguments apply)
 M.
-- ' Listen to the wind, it talks
          Listen to the silence, it speaks
             Listen to your heart, it knows
Ganado Mucho (1809 to 1893 ) Navajo Indian
are you using mgmt-vrf for VLAN you want to access ?
this VLAN can not access from any other port excpet the mgmt-port.
There is much that we do not know about this environment and that impacts our ability to give good advice. If you provide more detail we may be able to be more helpful. Here are a few things to start with:
- do you have IP connectivity to that switch? (ping is typically how to answer this but other ways are possible to verify connectivity).
- are you sure that SSH is enabled on that switch? If you have any other access to that switch the output of show ip ssh would be very helpful.
- as @Mark Elsen suggests it is possible that some firewall along the path is preventing the ssh. Is there any type of firewall along the path?
- some versions of code require stronger encryption protocols. Is it possible that the switch you can not access is requiring stronger protocol? Can you ssh to the switch from some other devices in your network (other switches or routers)?
- does telnet to the switch work?
- do you have access to the configuration of that switch? If so seeing certain parts of the config would be helpful. For example are there any restrictions configured on the vty (access-class for example)?
Rick
