Network Design project for my course
eliaswazar54520
Hello everyone,
Hope you are doing well during this pandemic. I need your help in my project on Cisco Packet tracer. I have google everything but I still can find my way to draw the network with all the conditions needed. Note that I'm new to Packet Tracer
Here is my project:
Small Company:
-Design a network and draw a layout including IPs and Subnets for a small company with 6 different VLANs.
-Your design should have redundant routers or L3 switches. And two uplinks to each access switch.
-wireless system should be available with different VLANs (controllable wireless solution with dot1x authentication).
-the company will have two different internet connections from two different ISPs with failover capabilities in case one connection is down.
If anyone can help me, that will be great.
Thank you in advance for your time.
E.
pieterh
you can start reading the Cisco validated designs
 Cisco Validated Design Program - Cisco Validated Designs - Cisco
although in may seem too much info, all you need is in there, like vlans, subnets, redundancy, site hierarchy
the below should get you started (project created and saved in Packet Tracer version 8).
- 6 Vlans
- HSP redundancy for all Vlans
- redundant DHCP servers on the L3 switches
- redundant ISP routers
The ISP router redundancy is accomplished through HSRP tracking of the interface connected to the ISP. There are many different ways to configure failover/redundancy, this is one of them.
Attached the zipped project file.
