Network documentation too
andrewcarl74
Community Member
Does Cisco has a tool to automatically document current network including router, switchs, firewall and their connected interfaces? If you know of any tool on the market please advice. Thanks
8 Replies 8
Lucien Avramov
Level 11
Level 11
Are you looking for network diagrams?
What more precisely are you trying to document?
I am looking for a tool that I could use to automatically discover my network devices, routers, switches, Firewall, Cisco phones, UCM, & Unity also to diagram the interfaces that are directly connected.
Leo Laohoo
Solarwind's LANsurveyor
www.solarwinds.com/products/lansurveyor/
10-Strike Network Diagram
www.10-strike.com/network-diagram
Yes I am looking for network diagram. Thanks for the response, I'll try the links.
Ok, then check this one out too:
CNA: Cisco Network Assistant: www.cisco.com/go/cca
Thank You lavramov
Hi Lucien,
THe link is incorrect. I believe it should be www.cisco.com/go/cna.
Thank you for the correction, it is /go/cna.
I made a typo.
