05-26-2017 06:47 AM - edited 03-08-2019 10:44 AM
I have a 4500-X running IOS-XE version 03.05.02. OSPF is configured with passive-interface default. There is a network statement covering interface Te1/9. The output of "sho ip osp interf"shows this interface in the OSPF process. However only when "no passive-interface Te1/9" is configured on the process does the network appear as an OSPF route on other OSPF speakers in the domain. It was my understanding that running passive-interface on an interface only prevents OSPF adjacencies being formed over the interface and not whether or the network associated with the interface is included in OSPF. Any thoughts?
Solved! Go to Solution.
06-01-2017 01:31 AM
Yes, you're correct, passive should only preclude forming an OSPF adjacency.
If shouldn't preclude the network from appearing in the topology.
If fact, on our network we also use passive-interface default and edge networks appear in the topology.
Te1/9 is up in both cases?
05-26-2017 06:58 AM
show the configuration
06-01-2017 01:31 AM
06-01-2017 01:31 AM
Thanks for the confirmation. Te1/9 is up in both cases. Perhaps something is getting stuck with the LSA generation. I'll do a bit of debugging at the next opportunity. Unfortunately the interface in question has gone into production so I'm not at liberty to just shut it down, try something out and observe.
