Network module fibre connectivity
Bab L
Hi.
We would like to add a fibre network module into our ASA.
I found this: ASA-IC-6GE-SFP-A=.
But the connection is over 2km long so we will require single mode.
What is the best solution? Is there a network module that supports single mode or do we have to do something differently?
Thank you
2 Accepted Solutions
You will require a SFP transceiver to install in your ASA-IC-6GE-SFP-A=.
as it is 2 km so single mode fibre is required
the one you want is a GLC-LH-SM (1000Base-LX/LH)
Richard.
yes,
see the data sheet
http://www.cisco.com/c/en/us/products/collateral/security/asa-5500-x-series-next-generation-firewalls/data-sheet-c78-729807.html
Richard.
Hi Richard,
so the network module ASA-IC-6GE-SFP-A=. will work as long as we use a different transceiver?
yes,
see the data sheet
Thanks a lot.
