problem microsoft wds server
goran ljubic
Level 4
Level 4
i have wds server(192.168.200.28) on segment 192.168.200.0/24 on another segment (192.168.0.0/24) are domain controller, DNS server, workstations for deploying. DHCP server is on mikrotik router 192.168.0.254. my provider is set option 66,67 on dhcp server. between those two segment is cisco router 1920. On router enable full access to WDS server. on interface from segment 192.168.0.0/24 i created ip helper-address 192.168.200.28. when i boot my workstation i receive error
pxe-t04 illegal operation error
pxe-036 error received from tftp server
pxe-mof exiting pxe rom.
on wds server i started wireshark and i received message like on pictures.
i don't know  that is my router make problem or not?
can you help me?
configuration interface from segment 192.168.0.0/24 is
interface GigabitEthernet0/0
description $ETH-WAN$$FW_OUTSIDE$
ip address 192.168.0.253 255.255.255.0
ip access-group Outside_in in
no ip redirects
no ip unreachables
no ip proxy-arp
ip nbar protocol-discovery
ip flow ingress
ip flow egress
ip verify unicast reverse-path
duplex auto
speed auto
no mop enabled
jbowman1985
Level 3
Level 3
Hi Goran,
In your description you listed your DHCP server as having IP address of 192.168.0.254.  Is this correct?  If so, then you would need to change your ip helper-address from 192.168.200.28 to 192.168.0.254.
yes, this ip address of dhcp server but when i set this ip address nothing, same problem.this mikrotik router is gateway and dhcp server for network 192.168.0.0/24. cisco router is between some servers  that are on network 192.168.200.0/24 and workstations with domain controller and dns server.
Sorry for my confusion, but is your DHCP server running on a server on your domain?  When you configured your WDS server did you make sure to integrate it with Active Directory?  When I was working on deploying Windows via MDT and WDS, I know I had to setup the DHCP server on a server in the Domain for everything to work properly.
in wds log i found
[357059][WDSTFTP] [WDSTFTP][UDP][Ep:192.168.200.28:69] Recv From:192.168.0.161:2070 Len:994
[2800] 15:05:48: [357059][WDSTFTP] -> CClientContext::FindSession
[2800] 15:05:48: [357059][WDSTFTP] <- CClientContext::FindSession=2
[2800] 15:05:48: [UDPPorts] Allocated dynamic port 50880.
[2800] 15:05:48: CUdpHandler::OpenEndpoint: Dynamic Port=50880
[2800] 15:05:48: [WDSTFTP][UDP][Ep=50880] Registered
[2800] 15:05:48: UpdEndpoint::UdpEndpoint = 0000000002D2E930
[2800] 15:05:48: [WDSTFTP][UDP][Ep=192.168.200.28:50880][0x0000000002D2E930] Created
[2800] 15:05:48: [357059][WDSTFTP] TftpSession[0x0000000002D2DEF0:192.168.0.161:2070] - Initialized: Local=192.168.200.28:0
[2800] 15:05:48: [357059][WDSTFTP] [d:\longhorn\base\ntsetup\opktools\wds\transport\server\tftp\tftpsession.cpp:566] Expression: , Win32 Error=161
[2800] 15:05:48: [357059][WDSTFTP] [d:\longhorn\base\ntsetup\opktools\wds\transport\server\tftp\tftpsession.cpp:614] Expression: , Win32 Error=161
[2800] 15:05:48: [357059][WDSTFTP] TFTPConstruct[ERROR]: Code=4(0x4), Desc=`Illegal operation error.`
[2800] 15:05:48: [357059][WDSTFTP] [d:\longhorn\base\ntsetup\opktools\wds\transport\server\tftp\tftpserver.cpp:592] Expression: , Win32 Error=161
[2792] 15:05:48: [357059][WDSTFTP] [WDSTFTP][UDP][Ep:192.168.200.28:69] Sent To:192.168.0.161:2070 Len:29
[2792] 15:05:48: [357059][WDSTFTP] [WDSTFTP][UDP][Ep:192.168.200.28:69] Recv From:192.168.0.161:2071 Len:999
[2792] 15:05:48: [357059][WDSTFTP] -> CClientContext::FindSession
[2792] 15:05:48: [357059][WDSTFTP] <- CClientContext::FindSession=2
[2792] 15:05:48: [UDPPorts] Allocated dynamic port 58856.
[2792] 15:05:48: CUdpHandler::OpenEndpoint: Dynamic Port=58856
[2792] 15:05:48: [WDSTFTP][UDP][Ep=58856] Registered
[2792] 15:05:48: UpdEndpoint::UdpEndpoint = 0000000002D2F8E0
[2792] 15:05:48: [WDSTFTP][UDP][Ep=192.168.200.28:58856][0x0000000002D2F8E0] Created
[2792] 15:05:48: [357059][WDSTFTP] TftpSession[0x0000000002D2EEA0:192.168.0.161:2071] - Initialized: Local=192.168.200.28:0
[2792] 15:05:48: [357059][WDSTFTP] [d:\longhorn\base\ntsetup\opktools\wds\transport\server\tftp\tftpsession.cpp:566] Expression: , Win32 Error=161
[2792] 15:05:48: [357059][WDSTFTP] [d:\longhorn\base\ntsetup\opktools\wds\transport\server\tftp\tftpsession.cpp:614] Expression: , Win32 Error=161
[2792] 15:05:48: [357059][WDSTFTP] TFTPConstruct[ERROR]: Code=4(0x4), Desc=`Illegal operation error.`
[2792] 15:05:48: [357059][WDSTFTP] [d:\longhorn\base\ntsetup\opktools\wds\transport\server\tftp\tftpserver.cpp:592] Expression: , Win32 Error=161
[2800] 15:05:48: [357059][WDSTFTP] [WDSTFTP][UDP][Ep:192.168.200.28:69] Sent To:192.168.0.161:2071 Len:29
[2800] 15:05:48: [d:\longhorn\base\ntsetup\opktools\wds\wdssrv\server\src\udpendpoint.cpp:811] Expression: , Win32 Error=5023
[1288] 15:05:48: [WDSTFTP][UDP][Ep=192.168.200.28:50880] Deleted.
[1288] 15:05:48: [357075][WDSTFTP] TftpSession[0x0000000002D2DEF0:192.168.0.161:2070] - Endpoint Removed. Killing session.
[1288] 15:05:48: UpdEndpoint::~UdpEndpoint = 0000000002D2E930
[1288] 15:05:48: [WDSTFTP][UDP][Ep=50880] Closed
[1288] 15:05:48: [UdpPorts] Dynamic Port 50880 freed.
[1288] 15:05:48: [357075][WDSTFTP] TftpSession[0x0000000002D2DEF0:192.168.0.161:2070] - Shutdown
[2792] 15:05:48: [d:\longhorn\base\ntsetup\opktools\wds\wdssrv\server\src\udpendpoint.cpp:811] Expression: , Win32 Error=5023
[1288] 15:05:48: [WDSTFTP][UDP][Ep=192.168.200.28:58856] Deleted.
[1288] 15:05:48: [357075][WDSTFTP] TftpSession[0x0000000002D2EEA0:192.168.0.161:2071] - Endpoint Removed. Killing session.
[1288] 15:05:48: UpdEndpoint::~UdpEndpoint = 0000000002D2F8E0
[1288] 15:05:48: [WDSTFTP][UDP][Ep=58856] Closed
[1288] 15:05:48: [UdpPorts] Dynamic Port 58856 freed.
[1288] 15:05:48: [357075][WDSTFTP] TftpSession[0x0000000002D2EEA0:192.168.0.161:2071] - Shutdown
[1288] 15:05:51: BufferPoolSet[Trim]: AllocSize=4096, Min=512, Last=258, Current=514, Trim=2
