network-policy self config on interface issue
Hi all,
we have noticed that when we issue command: show network-policy profile
switch does not return any result, but on most interfaces we have network policy configured:
interface GigabitEthernet1/0/1
description aaa
network-policy 1234567
also in previous backups we noticed that policy nr. has changed itself several times;
how can we explain this, we are not sure if we did configured any policy ?
catalyst 2900
Boris
10 Replies 10
balaji.bandi
show network-policy profile  - if this is not showing there is nothing offline configured 1234567
view better post  us show run.
you can find more information here :
https://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst2960/software/release/12-2_53_se/configuration/guide/2960scg/swlldp.html
BB
could that be anything online/dynamically configured , but as far as we know we are not using this;
here the tech support attached
balaji.bandi
Looks you have Do1.X environment with ISE - is this correct ? then it is coming from ISE.
BB
yes we do have ISE with 2.6 Patch 8. but
why then are only a few switches/network-policy profile affected of this?
We authenticate thousands of ports a day and all are authenticated against the same rule on the ISE.BR
balaji.bandi
That need to investigate properly -  check on the ISE Live Logs and check on the switch.
1. Define the problem
2. when was this started.
3. what changes were done before this causing issue.
sometimes hard to says what went wrong. if this is not critical reset the switch and put the config(minimal) and test it.
Other note you mentioned - catalyst 2900
as per the config, it was WS-C3560CX-8PC-S - are you investigating the right device?
BB
Hi ,
l think should be OK that we see the network-policy configured on the 2900 switch ports,
as we are using port authentication policies with ISE ?
on the last years backup of 2900 switch, we see network-policy profile Nr. 1234567 then
in the middle of the year is 3412456 and in the last backup 5431254.
we are only wondering why the network-policy number is changing itself ?
did not noticed when it started - seems one year ago , but we do not keep track of the configuration changes so long.
BR
is this the case only this switch or all the switches ?
BB
we have around 200 switches different series running different IOSes  and we noticed this only on 5 devices; all switches/ports are authenticated against the same rule on ISE.
any guesses ?
probably we should go for TAC
balaji.bandi
since its developped only few switch, others work, worth open a TAC and investigate for you.
BB
